bettley_smith's avatar
Jun 28, 2011
Remote Upload
Am I going wrong?, I can use the remote email to upload pictures and they appear, when I try the FTP upload, i can see then in the upload folder but they do not transfer to my Readynas Album.
  • shtijn wrote:
    How did you solved the problem with "Fail to access Photos II from internet. (error=-1).' ?
    Because I'm having the same problem...
    Thanks
    Are you running 1.0.2?
    Thanks
    yess... Is that the problem?
  • Hi,
    RE:
    bettley-smith wrote:
    Just moved to version 1.0.2, now get some problems listed and when i diagnose get this:
    OK: All connection tests from ReadyNAS Photos II to UPnP Router and photos.readynas.com site are passed.
    OK: Hostname BettleySmith is available.
    Error: Fail to access Photos II (http://78.149.xxx.xxx:8086) from internet. (error=-1).
    OK: Successfully found your public IP (78.149.xxx.xxx).
    (xxx) to hide identity
    What does this mean?
    I seem to have exactly the same problem. I have an ultra 4 sitting behind a DLINK upnp router/firewall; just tried to use ReadNAS photos II for first time and get same problem as above (RAIDiator 4.2.17; photos v1.02). Have been running for a while with my ReadyNAS accessible to internet via webDAV over SSL so i know i can get through the firewall to the ReadyNAS on the IP address - but seem to get absolutely nothing there when try to access port 8086... tried from inside and outside firewall using both internal and external ip addresses... any ideas anyone? Thanks.
  • OK, to answer my own question, i have now resolved this - i rebooted my router; and after that, it all works. Like it so far!
  • Folks is there a manual somewhere for this software?
    Sorry for asking this but Preferences, remote upload, passcode.... where is this used I'm trying to get remote uploads working
    thanks.. I'm glue-less on this .. I'm trying to get my family members to upload photos into the site..
    Badbruno
  • Darth_Vader's avatar
    Darth_Vader
    NETGEAR Employee Retired
    Badbruno
    There are a few ways you can do this:
    1. Allow your family members to login to your account to upload photos
    2. Create account for your family members, so they can login as themselves and upload photos
    3. Setup Remote Upload via Email or via FTP (Under Settings > Preferences > Remote Upload tab)
    Thanks
ProSupport for Business
