MarcusRosen's avatar
MarcusRosen
Disc degraded after Firmware upgrade to 6.5.2
Hi,
My NAS have been working fine  with the only issue  being very slow acces via Windows Exporer. I turned of the real-time anti-virus scanner and the issue went away.
I then updated to the latest firmeware 6.5.2 and after the upgrade the disc status shows up as degraded.
I have rebooted the unit a couple of times and and shut it down. I have take the "bad" disc out and etc.
Is the disc likely to have been corrupted as part of the firmware upgrade?
The logs can be found here: https://drive.google.com/file/d/0B9URWpaz62voc2ZFenlPVjkxUzQ/view?usp=sharing
Thanks
Marcus
  • StephenB's avatar
    I think it be wise to shut down the system and test disk 2 in a windows PC with lifeguard.  If you don't have a backup you should certainly make one - your data is at risk.
    One way to proceed is to back everything up, do a factory reset and then rebuild the NAS, and restore the data.
    There are some odd things going on in the logs. hopefully netgear will take a look.  spindown.log enables spindown on disk 2, but the disk never is spundown. This goes back to last June (as far as spindown goes back), so it is not new.
    disk_info.log only shows disk 1.  smart_history shows both disks (and both have a couple of pending sectors errors).
    There are a couple of other issues going on, which I don't really understand the cause.
    One is this snippet (which repeats)
    Sep 29 06:52:31 Rosen-NAS smbd[23255]: [2016/09/29 06:52:31.607780, 0] ../source3/smbd/oplock.c:192(update_num_read_oplocks)
    Sep 29 06:52:31 Rosen-NAS smbd[23255]: PANIC: assert failed at ../source3/smbd/oplock.c(192): d->num_share_modes == 1
    Sep 29 06:52:31 Rosen-NAS smbd[23255]: [2016/09/29 06:52:31.611268, 0] ../source3/lib/util.c:788(smb_panic_s3)
    Sep 29 06:52:31 Rosen-NAS smbd[23255]: PANIC (pid 23255): assert failed: d->num_share_modes == 1
    Sep 29 06:52:31 Rosen-NAS smbd[23255]: [2016/09/29 06:52:31.612039, 0] ../source3/lib/util.c:899(log_stack_trace)
    Sep 29 06:52:31 Rosen-NAS smbd[23255]: BACKTRACE: 0 stack frames:
    Sep 29 06:52:31 Rosen-NAS smbd[23255]: [2016/09/29 06:52:31.612518, 0] ../source3/lib/dumpcore.c:318(dump_core)
    Sep 29 06:52:31 Rosen-NAS smbd[23255]: dumping core in /var/cores
    There are also regular ethernet over-runs, which might be related to your poor performance.
    Sep 29 19:22:26 Rosen-NAS kernel: [395773.553715] mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
    Sep 29 19:22:29 Rosen-NAS kernel: [395775.997205] mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
    Sep 29 19:22:35 Rosen-NAS kernel: [395782.477936] mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
    Sep 29 19:22:35 Rosen-NAS kernel: [395782.477960] mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=512
    Sep 29 19:22:39 Rosen-NAS kernel: [395786.820422] mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
      The disks may have hardware issues. This wouldn't be caused by the firmware upgrade.
      Do you have a backup?
  • kohdee's avatar
    kohdee
    NETGEAR Expert
    It is unlikely that your disk failed due to an upgrade. Typically, if you have used a disk for awhile but you aren't processing much data on it (it just sits around), then you don't activate any bad sectors, but upgrading/rebooting might cause it to pass over bad sectors and fall out,.
    It looks like your drives have counted up a few errors historically (see smart_history.log), but not too many.
    On Sept 30 around 19:33:16, your disk tried to come online but it was having some kind of read errors.
    You can see constant complaints in the dmesg.log trying to identify the disk.
    [Fri Sep 30 19:34:15 2016] ata1.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
    Your drive in bay 2 seems to have been collecting errors, as well. Not too many though.
    • MarcusRosen's avatar
      MarcusRosen
      Thanks for all the replies. :)
      I'm backing up all the data on external drives right now (likely to take some time).
      Is it likely that I need to replace the Bay 2 drive or could it be the NAS itself?
      How can I proceed one all the data is backed up?
        mdgm-ntgr
        You can hook the disks up to a PC and test them using the vendors tools e.g. SeaTools for SeaGate disks or WD Data LifeGuard Diagnostics for WD disks.
ProSupport for Business
