BALR1415's avatar
BALR1415
Disk tray for ReadyNAS Duo
I received a ReadyNAS RND2150-100NAS as part payment for some work. It however does not have any disks or disk trays. I used a loaned disk to test it and it seems fine. Searching this forum I beleive that the disk-tray for the ReadyNAS NV and NV+ is the same as the Duo. Is this correct? the part number is RND4TRAY1-10000S.
And any info on wher to buy?
  • If when you get the trays, if they don't include the screws, for a temporary fix you can rob some of the small flathead screws holding the side panels on, and the back plate on. The drives are ok with just two screws in a diagonal pattern. (That hint of only two screws came from a Jedi who mentioned they do that in the lab when testing drives).
    Then ask Netgear for some. If they are unwilling to send some, post back.
  • Thank you both for the information.
    Amazon had the tray listed (and free shipping). I ordered it Friday and it got here Monday - by USPS!!!
    However I had a hard time opening the latch - the button could not be pushed in. I keep trying to depress the button unsuccessfully with no luck - until I slid a small plastic tab (inside the tray behind the button) up. And then the latch snapped open. Is this a locking mechanism? It seems like a dangerous thing.
  • Work the release latch several times to wear down the flashing marks and it should work easier. Initially the ones on my NV+ stuck on occasion, but after working them a bit, I have never had one stick again.
ProSupport for Business
