Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly.
First, you will need a Uninterruptable Power Supply (UPS) with a USB connection. It doesn't have to be a large one, just big enough to protect the data in case of the power failure. A 250VA unit will be more than adaquate. Plug the ReadyNAS in to the power plug in on the UPS, making sure you plug in to the protected outlet. Next you need to connect the USB connection from the UPS to USB connector on ReadyNAS. Now turn it on.
Once the UPS is connected, ReadyNAS will automatically turn on the Write Cache option on drives. For further increase of writes, turn off the full journaling option. You can do that by clicking on the System button. If you don't see the System button, make sure you click on the Advanced Control button first. Then click on the Performance tab on the top. Then check the second option, Disable full data journalling for RAID 5 volumes, and click apply.
You should now see a large improvement on write performance of ReadyNAS.
- yoh-dahGuide
JReble wrote: I'm only getting about 4.5 MB/sec write speed out of my new X6. I've got a ups with usb port attached, write cache enabled, and I'm using gigabit network cards with a Netgear 5 port Gigabit Ethernet Switch model GS605. Read speeds appear to be satisfactory, but my write speeds are terribly low. What would you suggest?
Try disabling the journal. But we do recommend you have a UPS to avoid lengthy filesystem check after powerfail. - JRebleAspirantIt's already disabled. From previous posts I'm expecting 2 to 3 times this write speed. :cry:
- yoh-dahGuide
JReble wrote: It's already disabled. From previous posts I'm expecting 2 to 3 times this write speed. :cry:
Do a quick IOMeter test (see http://www.infrant.com/forum/viewtopic.php?t=265 ) and let me know what you get for read and write. - JRebleAspirantOk, ran the tests as indicated....
Write results:
Write IOps: 32.062291
MBps: 8.015573
Transactions Per Second: 32.062291
Avg Response Time: 31.183962
Read Results:
Read IOps: 102.222964
MBps: 25.55574
Transactions per Second: 102.222964
Avg. Response Time: 9.776898
Seems to be writing too slow. :( - yoh-dahGuidePlease re-run with direct-connect (no need for a cross-over cable). The ReadyNAS will show up as IP 192.168.168.168.
JReble wrote: Ok, ran the tests as indicated....
Write results:
MBps: 8.015573
Read Results:
MBps: 25.55574
Seems to be writing too slow. :( - JRebleAspirantNot using a cross over cable. Using the included patch cable from X6 to ethernet switch, straight through cables from switch to computers.
New Write results:
Write IOps: 29.746077
MBps: 7.436519
Transactions Per Second: 29.746077
Avg Response Time: 33.61286
Read Results:
Read IOps: 106.476407
MBps: 26.619102
Transactions per Second: 106.476407
Avg. Response Time: 9.3866678
I can get considerably faster speeds between my computer and a drive mapped from another computer on the network. The NAS continues to be very slow in the write department. - bhoarAspirantJR - Yoh-dah was indicating you should take the switch out of the equation and connect the desktop *directly* to the readynas using a single gigabit ethernet cable.
-brendan - JRebleAspirantAh...Thanks...I missread. Trying that now.
- JRebleAspirantDirectly connected, same results. :cry:
- JRebleAspirantAnyone got any fresh ideas? Still pretty poor write speeds from our new X6 even directly connected to a single PC. At this point, I'm wondering if I should box it up and ship it back??
