carpii
Aug 26, 2012Tutor
Multiple failing Seagate Barracuda ST32000542AS
I bought 3 ReadyNAS (over the course of 5 months), and populated them all with identical Seagate Barracuda's
They are the Barracuda LP ST32000542AS model, on the HCL and I chose these because there were no special firmware requirements
Over the past month, one of my NAS is starting to send regular SMART email alerts, about disk problems
Initially it was disk 1, but the past week Disk 4 is also starting to get errors
Has anyone had a similar experience with these drives?
Could it be something to do with the NAS chassis?
My other 2 NAS (including the oldest one) use the same drives without problems
Im starting to think I made a rookie error by buying homogeous drives.
- carpiiTutor
StephenB wrote: You can use 3 TB drives with your 2 TB drives if you are using XRAID2 and have firmware of 4.2.16 or later.
Thats great, Thanks Stephen
Im using 4.2.19 and XRAID2 :P - PapaBear1ApprenticeBe sure to back up all your data before you start and replace the drives one at a time. After you have replaced the second drive, it will take at least one and maybe several reboots before the vertical expansion starts and it will take much longer than the resync.
I when through this when I replace two 1TB drives with two 3TB drives on both of my NVXs. - carpiiTutor
PapaBear wrote: Be sure to back up all your data before you start and replace the drives one at a time. After you have replaced the second drive, it will take at least one and maybe several reboots before the vertical expansion starts and it will take much longer than the resync.
The failing NAS is actually just a backup NAS for my 1st one. I rsync it across each night
I havent done a volume expansion before, so thanks for the tip! - PapaBear1ApprenticeSounds like my set up. Two NVX units, one is the primary and mapped in Windows, the other is the nightly rsync back up target of the first.
In that case I would go ahead and update the drives in the backup. When I do any updates, I do it on the backup (NVX Pioneer) before I do it on the primary (NVX BE) a week later.
- Aug 17, 2011Retired_Member
