jawknee's avatar
jawknee
NV+ 2TB Limit - Was Disappointed, Now Happy
I bought an NV+ a couple of years back and was happy to see the improved support for Timemachine. But, with just 2 1TB drives I was limited to ~600GB. I did my research and settled on the Western Digital WD20EARS drives - I got 4 of them.
I did the RAIDar upgrade and factory reset and all went well (saved the original drives as a "backup" plan and started clean with the 4, 2TB drives).
I got 5.4 TB's of space - right in line with my expectations. But could not expand the timemachine space above 2TB. After quite a bit of searching, I discovered that the SPARC based machines - including my NV+, do not support files greater than 2TB, nor are there any plans to.
So - my questions are, why even bother selling and certifying new 2TB and larger drives if your file system is stuck in the past? Why even continue to SELL the NV+, when they have no business living in the future? Why not make a note in the certification (like was done to point out that the 4k sector size required a factory reset) saying that timemachine could not make use of more than 2TB? Just what OS do you have on this that can't handle great than a 2TB file size?
I bought this (at quite a bit more than they're selling now) because it was upgradable and a solution for the future. Turns out the future was only a year or two away.
Not sure if this was the original reference, but this the specific limitation I'm referencing: viewtopic.php?f=71&t=49058
ProSupport for Business
