Charles_R
May 19, 2012Aspirant
NV+ v2 with WD30EZRX
I purchased both of the above on May 7th via a Amazon bundle (for a great price) and when I purchased them I'm 99.99% sure the drive was listed as compatible with the NV+ v2. Installation went fine and I didn't have any issues until I tried to attach a USB drive to the NV+ v2. Every time I would attempt to copy roughly 800GB to the USB drive the NV+ v2 would drop off the network more or less freezing (requires a plug pull). It was a USB 3.0 drive so I tried the USB 2.0 port as well and had the same issue. Much later on I also tried a completely different USB drive (multiple cables too) and had the same issue. Further more I have replaced the NV+ v2 thinking perhaps it was defective and still had the same issue. I also did several Factory Defaults.
So long story (some what short) I have tried numerous NV+ v2 and USB drives and every time I attempt to copy the same 800GB data the NV+ v2 crashes. It also crashes if I direct connect a PC to the NV+ v2 (via Ethernet). So it appears whenever the transfer rate is fairly high it crashes. I have transferred the data multiple times over my 100Mbps network to/from the NV+ v2 without issue. I haven't had one that I can remember...
Since the only thing I haven't replaced is the original 3TB drive (model listed above) I'm beginning to have my doubts about it. As I can't believe the behavior is normal and I'm not far from shipping everything back and calling it quits. I copied the same data to/from two low-end NAS devices without any issues and I certainly expected this guy to keep up.
So since I began questioning the drive (I have done a few check disks which report no issues) I took another look at the compatible drives at ReadyNAS.com and notice it's not on the list. I swear it was before... and it's on the list for the Duo v2 which I would think would support the same disks. Since it's not on the list I have ordered one that is and I'm going to give it a try. Which leaves me with two questions...
Thanks.
- Is having the NV+ v2 dropping from the network (only when transfering data fairly quickly) typical behavior?
Are people having the same issue with supported drives?
Thanks.
- mdgm-ntgrNETGEAR Employee RetiredCan you try a direct-connection and see if you still get the issue?: http://sphardy.com/web/directconnect
Please use a Cat5e or newer ethernet cable when doing the direct-connect.
If it still drops off doing the direct-connect then check to see if the NIC drivers in your PC are up to date.
A 100Mbps network is slow. You might wish to purchase a gigabit router/switch and connect the NAS to your network via that. You could also connect devices with gigabit ethernet to the gigabit router/switch to get gigabit speeds between those and the NAS. - Charles_RAspirant
mdgm wrote: Can you try a direct-connection and see if you still get the issue?: http://sphardy.com/web/directconnect
Yes - as I stated I tried a direct connection. Via a MAC and PC. Same issue.If it still drops off doing the direct-connect then check to see if the NIC drivers in your PC are up to date.
Again it has happened with different hardware.A 100Mbps network is slow.
I know. But so far that's the only speed that works. Using a attached USB drive backing up to or from the NV+ v2 (tried all three of the NV+ v2 USB ports) or direct connection the NV+ v2 crashes. Since it does in both situations it appears to be hunting ghosts looking beyond the NV+ v2 itself and or its drive. - mdgm-ntgrNETGEAR Employee RetiredWhat version of RAIDiator?
Does it crash over both CIFS and AFP? - Charles_RAspirant
mdgm wrote: What version of RAIDiator?
I have been using Beta 5.3.5 (T10 - T33).Does it crash over both CIFS and AFP?
Note it crashes doing a backup from its internal drive to and from the attached USB drive. I know it crashes with CIFS (via the PC I used) as well as AFP when I tried via a Mac (believe that is what I was using). - WishAspirant
Charles R wrote: So since I began questioning the drive (I have done a few check disks which report no issues) I took another look at the compatible drives at ReadyNAS.com and notice it's not on the list. I swear it was before... and it's on the list for the Duo v2 which I would think would support the same disks.
Funny that, I thought I saw them on the list too because they were the drives I was originally going to get.. - Charles_RAspirant
Wish wrote: Funny that, I thought I saw them on the list too because they were the drives I was originally going to get..
My only guess is it was found to be non-compatible. I'm hoping so as other wise given the issues I've been having I give up. Looking into other possibilities I noticed one of their major competitors list 158 supported drives (for a similar model) versus 21 for NV+ v2. - Charles_RAspirantToo early to tell anything however I received my Seagate 3TB ST3000DM001 and sent the WD30EZRX back to Amazon. Installed fine and I instantly upgraded to Beta T41. So if any of the issues were related to the early Beta who knows and who cares... if they go away. :) I will say this drive appears noisier and runs a little hotter (not that I care).
I direct connected the NV+ v2 to my Mac Mini (old, slow guy) and started dumping the data back (roughly 1.25GB a minute) onto it via an external USB drive attached to the Mac (it's formatted for Mac so I can't attach it directly to the NV+ v2). I would have used ext3 or NTFS but as posted earlier the NV+ v2 would crash every time I tried such so I went the old slow proven path.
I have about 1TB to copy over and doing a direct connection before it would crash regularly. So far I'm only around 50GB but so far so good... here's hoping. If it does crash I can't think of anything else to try...
- I have tried several NV+ v2 (all with the same issue).
- I have tried two USB drives (direct connecting to the NV+ v2)
- I have tried various cables
Up until now it has crashed whenever I try to transfer 800GB or more (in several large chunks) via it's attached USB ports (tried them all) or via direct connection to a Mac or PC. As before hopefully the WD drive just doesn't work and that's why it was removed the compatible list. However, if it now fails I'll appreciate any suggestions before giving up and returning it. - Charles_RAspirantIt appears the drive isn't compatible or was simply defective. After swapping for the Seagate (posted earlier) restoring the 1TB back on the NV+ v2 went like a champ and right now I'm doing an attached USB backup which is motoring right along via one of the USB 3.0 ports. Moral of the story don't use the WD30EZRX in your NV+ v2... unless I got unlucky and it was defective. Now if it had simply been removed from the list a few days before I purchased mine I'd have a lot more free hours in the bank. :)
- gandalfnetAspirantthese drives work PERFECT with large file copies with firmware version 5.3.2
Had it for over a month and copied over 5 TB of data with no issues.
BUT the new 5.3.5 totally breaks these drives and will crash your NAS on big file copies...
Is there anyone that can get ahold of the Firmware folks and let them know?
This drive is on the compatability list for the DUO V2 but not the NV+ V2 (I could of swore it was on before)
Which does not make sense since it looks like the DUO and the NV+ V2's are idendical...
Gandalf - otto_mateAspirantWe have 3 x WD30EZRX drives in our NV+ v2, bought as they were in the HCL. Nice work on just removing then from the list there Netgear!
Having the same issue copying over a large file (580GB).
Where do I open a ticket with these jokers??
Thanks
