mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp running out of spec?
Any idea what to do? A calibration of the cpu fan is not offered within frontview...
Thanks in advance for any hint!
- chirpaLuminaryWhat firmware are you running?
- muleAspirantWow that was fast ;-)
I'm running V4.2.13-T10. - chirpaLuminaryWhat firmware release before that, and was it okay then?
- muleAspirantAfter having a look at the logs i can tell that the first message "running out of spec" arised while using 4.2.12-T30.
- muleAspirantOne additional info (don't know if it helps): 15 Minutes ago i opened the case directly after shutdown and the cpu cooler seemed to be rather cold (didn't measure it but comparing it to body temparture i would assume it was around 35 degree) although frontview reported about 61 degree before shutdown?! May there be a contact issue between cpu and cooler? Already checked the screws of the cooler but all are fixed as they should...
- chirpaLuminaryWith the side panel off, is the CPU fan a 4-wire plug going to the mainboard, or a 3-wire plug going to the daughter board near the back? http://www.readynas.com/?p=1912
- muleAspirantAlready checked it, it's a 4-wire one connected to the main pcb.
- chirpaLuminaryPlease send in your system logs (link in my sig).
- muleAspirantThanks for help! Logs sent...
- beisser1Tutorchirpa he probably has the same issue as i did on my pro. reverting to 4.2.11 should instantly fix that. newer firmwares report cpu temp 5 degrees too high which generates these warnings.
