tranqme
Aug 09, 2015Aspirant
RN31400 Power Adapter #25564575
Hello,
I'm after a replacement power adapter for a NetGear RN31400, the same as what is in the link below.
Any advice is appreciated.
- tranqmeAspirantI ended up purchasing a replacement adapter off eBay but my unit was faulty.
Where are you located? Might be able to help you out. - StephenBGuru - Experienced User
Did you try Netgear support? If you are the original purchaser they should replace it if it failed.
All RN314 should still be under warranty.
- tranqmeAspirant
Yes I have, and because I purchased it second hand the warranty is non-transferable which is ridiculous.
On top of that they can't even provide me with advice on where to purchase a replacement adapter.
- JennCNETGEAR Employee Retired
Hello tranqme,
Unfortunately NETGEAR only provides warranty to the original owner of the product that is why they require sales invoice issued by the authorized reseller when authorizing replacement. They do not provide any support nor warranty to refurbished and pre-owned units, that's also why registration is non-transferrable unless it is proven that you have purchased the product from the reseller as brandnew/unused and sealed.
You might want to check at NETGEAR Australia online resellers, perhaps they can sell power supply for your ReadyNAS 314. The part code of the power supply 12VDC,7.5A is 332-10581-01, some resellers use this part code.
I hope this helps.
