gyves1's avatar
gyves1
Luminary
Oct 25, 2025
Unable to activate the SMB
Hi,
Since several days I had an unexpected disabling of my SMB on the ReadyNAS.
I'm trying to reactivate the service but each time the App button go back to grey status.
Do you have an idea of the root cause ?
Thanks
  • I did the factory reset, the SMB is back now, but I have odd behavior with AV. Also with my eSAta2USB-c, which I'm unable to connect an external disk, only on the USB ports
    • StephenB's avatar
      Can you give more details?
      I never had much luck with eSATA myself (either with ReadyNAS or with a PC).  Though it's been a long time since I tried it (and I never tried an eSATA to USB-C adapter).
      Although the older linux on the ReadyNAS sometimes doesn't handle USB hubs properly, you can try connecting one to the USB output on the back and see if that works.
      • gyves1's avatar
        gyves1
        Luminary
        Hi StephenB,
        Sorry for my very late reply, I tried a lot of trials before to send you feedback. I waited the second reply of Netgear support, but nothing total silent. Only one reply which I replied to answer their questions but now nothing from them.
        Many thanks for your help. So The AV can't start due to an unknown network issue detailled in the log, all internet systems work on my network...the Transmission app on my ReadyNas is working fine without problem.
        I'm very boring by the situation and the lack of reliability of Netgear. To stop my loosing time with them, I will buy a new NAS from a more reliable manufacturer. Maybe I will find a good deal with the black friday
        Enjoy the holiday season!
  • Hi,
    Currently I'm trying to make a backup before to do factorry reset of my ReadyNas but the device is completly unstable like a DDOS of the WebUI...so often busy to download the Web page , restarting the logging popup...
    I'm searching a solution for this manual backup of my data before the reset
    • StephenB's avatar
      Do you have access to a linux system?
      • gyves1's avatar
        gyves1
        Luminary
        Unfortunately no :-(
        I forced the poweroff from the front panel.
        I bought a new external SSD 2TB and an eSata/USB-C cable to make the ReadyNas Backup.
        I restarted the ReadyNas, it seems more stable, I have access to WebUI now.
        I connected the new external SSD (formated in GPT with a NTFS partition) on the eSata...nothing on the WebUI, same with the rear USB. Only the front USB can find/start the external SSD.
        I think there a hardware problem with the rear USB and eSata.
        So now, I started the full backup of the ReadyNas on my external SSD Samsung 9100 2TB, faster than my previous external disk.
        I let you know when it's finished...after that I will try a factory reset of the ReadNas and check if the SMB service can be enabling or not after this master reset.
        If not, I will open an RMA ticket to Netgear support because my RN422 still under official warranty for 1 month
  • I have a new information over the SMB issue, when I'm trying to start the SMB service, an error pop-up is shown...
    • StephenB's avatar
      This is not an error I've seen before.
      Do you have any NAS user accounts that you are not using anymore?  If you do, then try deleting them.
      gyves1 wrote:
      but there is no "guest" user
      There is - but it is built in, not something you configure from the NAS web ui.
      If a device tries to access a share without using a NAS user account credential, then the NAS will use Guest (which amounts to anonymous access).
  • Sorry for this long waiting time, the Scrub is taking a very long time
  • But the SMB service on the main page is still disabled :-(
    • StephenB's avatar
      How full is the OS partition (/dev/md0)???
      Do you have a backup of your files?
  • Very odd, I lost all shared accesses
    But I was able to restore them and activating the SMB from the shared folder
  • That is usually the result of a corrupted configuration file, and a typical cause for that is a too-full OS partition.  If that is the case, you'll see warnings about it in the log.  There are things that you can try (using SSH and the Linux command line) short of a full reset, but we need to know what's the root cause, if possible.  If the OS partition is too full, do not do an OS re-install -- it'll most likely make the problem worse.
    • gyves1's avatar
      gyves1
      Luminary
      I don't see full OS partition
      I started now a defrag of the system
      I have 2.63TB free space on disks
  • I downloaded the full log zip but hosnestly I don't know where to check...
    I read the SMBstatus but I see only this string: using configfile = /etc/samba/smb.conf
    • Sandshark's avatar
      Sandshark
      Sensei
      If the OS partition is too full, the warnings are in the main log you can view from the UI.
      • StephenB's avatar
        If you like, you can send me a PM with a download link, and I will take a look.
        Make sure the permissions are set so anyone with the link can download.
  • What do you mean by full OS partition? A full reset of the RN?
    • StephenB's avatar
      Linux, the ReadyNAS software, and the configuration files are all saved in a 4 GB OS partition on the disks.  If that gets full, then many things can go wrong.  That includes config settings that don't "stick".
      The logs page errors normally call this a "full root".
      You can also see how full the OS partiton is by looking at the end of volume.log  Scroll down to the "df -h" section and look at /dev/md0:
      === df -h ===
      Filesystem      Size  Used Avail Use% Mounted on
      udev             10M  4.0K   10M   1% /dev
      /dev/md0        4.0G  981M  2.8G  26% /
  • StephenB's avatar
    Is this with an RN312?   If not, then what model NAS?
    Have you looked at the full log zip?  In particular, did you check for a full OS partition?
    • gyves1's avatar
      gyves1
      Luminary
      Hi StephenB,
      Glad to see you again on forum since long years :-)
      My model is the RN422
      I just saw the log from RN I saw just an error with the AV updating (it's a know issue from RN endlife  as I read)
ProSupport for Business
