tarobun
Nov 24, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091.
If it doesn't work after installation, try rebooting.
Not sure if it can be install over the top of super-poussin's version, but if you are planning on uninstalling super-poussin's version then remember to save the torrent files somewhere else first.
To quote myself:
Thanks to super-poussin for the original Transmission add-ons.
Enjoy!
Transmission_2.73.bin - http://www.mediafire.com/?ajpyyc7ujv54o37 no-utp
Transmission_2.75.bin - http://www.mediafire.com/?gbmbhu3hrabf9fe
Transmission_2.76.bin - http://www.mediafire.com/?389i53w9w9rtosm
Transmission_2.77.bin - http://www.mediafire.com/?pm420vuajaim9bz
Transmission_2.80.bin* - http://www.mediafire.com/?5s7dag8ko72doj1
Transmission_2.81.bin* - http://www.mediafire.com/?x4pvvidrgb36df2
Transmission_2.82.bin* - http://www.mediafire.com/?rbctsdae000zoav
Transmission_2.83.bin* - http://www.mediafire.com/?31iul25i0t12qda
Transmission_2.84.bin* - http://www.mediafire.com/?rh5fge4mc8ahzw4
*if the "Upload" button doesn't work or the "Destination folder" field is blank, reload the webpage.
To quote myself:
tarobun wrote: It looks like upgrading from Transmission 2.42 to this Transmission add-on is a no-no. Sounds like there are conflicting configuration that screws up both installs. :( (eg. /c/addons-config)
It seems the best approach is to fully uninstall the old, delete the config directory, and then install this add-on. Once you're on this add-on, updating is straightforward and can be done over the existing version.
Just a fyi - the default download dir is /var/local/Downloads and there is no username and password with this add-on. If you are prompted for them then the old version was not fully uninstalled.
Enjoy!
- chucko58AspirantThank you tarobun for this build! I deleted 2.42, installed 2.82, and it's working just fine - after I figured out that the web interface port changed.
- geojayGuideI've just installed Transmission 2.82 and I've tried to access it remotely (I've set up port forwarding on my router) but get a 403 response (Unauthorized IP Address). It works fine locally. Looking at addons-config\Transmission\settings.json I can see the line:
"rpc-whitelist": "127.0.0.1,10.0.0.*,192.168.*.*",
My router is on 192.168.1.70 so it looks like it should work. Can anyone suggest what the issue is and what I need to do to resolve it?
Thanks - NAS_tAspirantI've installed v 2.82 on my Duo (sparc) with 4.1.13.
It seems to have installed properly, and the little green light is on.
The ReadyNAS Status pages says "The Transmission add-on has been successfully installed."
When I click the button titled "Transmission Interface", a blank Firefox window opens. Its URL is "about:blank".
I tried rebooting the Duo. No change.
How does one access the GUI, and why does the Transmission Interface button point to a blank webpage? NAS-t wrote: I've installed v 2.82 on my Duo (sparc) with 4.1.13.
Have you got a PHP package installed? You will need one.
There is a free app from Super_Poussin for Sparc and x86, or some modern releases from WhoCares? which is not free. (Though I have a vague memory of WhoCares? releasing a slightly older PHP version for free, maybe?)- Mr_BGuide
Uh... I do? Weird. I don't have any PHP addon installed, and the interface button works just fine.InTheShires wrote: Have you got a PHP package installed? You will need one.
I've had 2.82 installed on my NV+ for quite some time. I'm still on 4.1.12, but unless something broke the interface, it should work "out of the box"NAS-t wrote: I've installed v 2.82 on my Duo (sparc) with 4.1.13.
The only thing i can think of is that your port number is wrong.NAS-t wrote: When I click the button titled "Transmission Interface", a blank Firefox window opens. Its URL is "about:blank".
Look in: \\"YourNASHere"\addons-config\Transmission\settings.json
Your looking for "rpc-port": 8181,
8181 is MY port. You have to find out which is yours. And , if you have a favorite number, you can change it to use that. For reasons not to be explained right now, stay above 1023, and below 65535 and you'll be fine.
Once you have a number, the current, or the one you changed to, check so the number matches in the text-box on the Frontpage-page. At this point you can try it again.
Remember to stop the service before you try and save the edited file. Might even have to stop the service to get read access, for some reason. (I don't have to, but i remember having to, earlier. Not sure if it's user rights, firmware, or Transmission that changed to make it "not be needed".)
The GUI is accessed through the button on that wep-page, but honestly. Get Transmission Remote or Transmisson Remote GUI. It takes a little to figure out how to configure them, but once thats done, it's a lot more user-friendly... No, not kidding, get one of them. The second seams to be more advanced, but does something weird every now and then. For what ever reason it makes the x86 Transmission i got running on a HP WHS freeze up if i leave the app running. Get that one, and see how it works for you. (Still, we should figure out what ti takes to get the web GUI running for you, it should wok, as a backup, if nothing else.)NAS-t wrote: How does one access the GUI, and why does the Transmission Interface button point to a blank webpage?
B! - NAS_tAspirant@Shires,
Thanks for the reply.
No, I don't have a PHP package installed, unless that's something that is part of the ReadyNAS RAIDiator software. (I don't know what a PHP is, nor what I would do with it if I had it!).
However, thanks to advice from someone with a lot of experience using Transmission on OS X, I've discovered that the Transmission Interface for v2.82 can be accessed at http://nas:9091/transmission/web/
( "nas" is the local network name of my Duo).
Apparently, port 9091 is the standard port used by Transmission on a Mac, so I tried it on the Duo, and was in like flint.
I've been able to initiate a torrent, which is downloading to the Duo as I type this. So far so good. - Mr_BGuide
Put 9091 in the textbox on the web-gui launch page, and see what that does for you. If it works... Push "save" before closing the page.NAS-t wrote: I've discovered that the Transmission Interface for v2.82 can be accessed at http://nas:9091/transmission/web/
B! - NAS_tAspirant@ Mr_B,
Confirmed - PHP not required. Transmission seems to be running fine right now on my Duo, and I've not installed a PHP package.
Thanks for the pointer to Transmission Remote GUI. I may check it out, but things seem to be working right now, and I'm not sure I want to add yet another layer of new software. Transmission Remote won't help me since it's a Windows program and I have a Mac.
I tried looking for \\"YourNASHere"\addons-config\Transmission\settings.json
Actually, I looked for //nas/addons-config/Transmission, since OS X uses forward-slashes instead of back-slashes. But no such folder is found.
You suggested that I put 9091 in the textbox on the web-gui page, and then push Save. Are you referring to the web page on FrontView which lists the Transmission add-on? On my Duo, there's no place to enter a port number.
Regardless, since I now know how to access the web page (at http://nas:9091), I don't need to go fiddling around with the port number.
Cheers! - Mr_BGuide
Do IT *tries to sound like Peanut, from/in "Spark of Insanity"* No really. Your just adding a magnet url handler. It pops up like any torrent client, has virtually no CPU usage, since it's not actually DOIN anything, the NAS does it all. And, when you don't use it, you just kill it off, and the NAS doesn't care.NAS-t wrote: Thanks for the pointer to Transmission Remote GUI. I may check it out, but things seem to be working right now, and I'm not sure I want to add yet another layer of new software.
Weird. I'm guessing the share isn't added, or it's shared "as something else". Since my NAS speaks Swedish i can only guess, but i think you need to look under "shares" and see if there is anything there that seams to point at configuration stuffs for the addons.NAS-t wrote: I tried looking for \\"YourNASHere"\addons-config\Transmission\settings.json
Wait... What? Right above the "Show Web Interface" button for the Transmission GUI, i have "Transmission RPC Port (from settings.json):" and a text box to enter info in. Thats where you should put 9091. You don't have that text box?NAS-t wrote: You suggested that I put 9091 in the textbox on the web-gui page, and then push Save. Are you referring to the web page on FrontView which lists the Transmission add-on? On my Duo, there's no place to enter a port number.
B! - NAS_tAspirantNope - no text box for the Transmission RPC Port.
On my Duo, the Installed Add-ons page contains a section titled "Transmission. P2P Client". In the upper-right corner is a little green dot (indicating that the add-on is active, I presume).
Below that, it says: Please disable the add-on before modifying the /addons-config/Transmission/transmission-daemon/settings.json file
Below that is a button titled "Transmission Interface", and another button "Create Torrent".
Finally, an invitation to send a donation via PayPal.
Lower-right corner has v2.82.
Perhaps you're referring to another web page?
