tarobun
Nov 24, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091.
If it doesn't work after installation, try rebooting.
Not sure if it can be install over the top of super-poussin's version, but if you are planning on uninstalling super-poussin's version then remember to save the torrent files somewhere else first.
To quote myself:
Thanks to super-poussin for the original Transmission add-ons.
Enjoy!
Transmission_2.73.bin - http://www.mediafire.com/?ajpyyc7ujv54o37 no-utp
Transmission_2.75.bin - http://www.mediafire.com/?gbmbhu3hrabf9fe
Transmission_2.76.bin - http://www.mediafire.com/?389i53w9w9rtosm
Transmission_2.77.bin - http://www.mediafire.com/?pm420vuajaim9bz
Transmission_2.80.bin* - http://www.mediafire.com/?5s7dag8ko72doj1
Transmission_2.81.bin* - http://www.mediafire.com/?x4pvvidrgb36df2
Transmission_2.82.bin* - http://www.mediafire.com/?rbctsdae000zoav
Transmission_2.83.bin* - http://www.mediafire.com/?31iul25i0t12qda
Transmission_2.84.bin* - http://www.mediafire.com/?rh5fge4mc8ahzw4
*if the "Upload" button doesn't work or the "Destination folder" field is blank, reload the webpage.
To quote myself:
tarobun wrote: It looks like upgrading from Transmission 2.42 to this Transmission add-on is a no-no. Sounds like there are conflicting configuration that screws up both installs. :( (eg. /c/addons-config)
It seems the best approach is to fully uninstall the old, delete the config directory, and then install this add-on. Once you're on this add-on, updating is straightforward and can be done over the existing version.
Just a fyi - the default download dir is /var/local/Downloads and there is no username and password with this add-on. If you are prompted for them then the old version was not fully uninstalled.
Enjoy!
- metosxAspirantHi and thanks for this release.
So far, no pbms installing it "over the top" of super-poussin's one.
After the installation, I stopped it copy all files from /addons-config/Transmission/transmission-daemon to /addons-config/Transmission then restart.
I get back all settings from previous installation (2.42 by super-poussin).
Otherwise, you stay on port 9091 and download incomplete data to /var/local/Download which is a none writable destination.
Thx again for this add-on. - TrukhinAspirantHmm... Build size reduced from ~20 MB to ~2MB (2.42 -> 2.76)?
- tarobunTutorYep, that's the file size with all debug symbols stripped.
- tarobunTutorUpdated to version 2.77
Changes:
All Platforms
Fix 2.75 regression that broke JSON parsing of real numbers in locales that don't use '.' as a decimal separator
Don't invalidate the OS's file cache when closing files
Fix overflow error when setting speed limits above ~8589 kB/s
Generated magnet links didn't include webseeds
Fix minor memory leaks when using webseeds
Daemon
Fix documentation errors in the spec and manpages
Web Client
Fix minor DOM leak - Mr_BGuideJust removed super-poussin's 2.42, updated the NV+ firmware to 4.1.10, and installed your 2.77 transmission client. Took me a bit of fiddling to get the download directory and stuff where i wanted it, but that was more on me, then on your piece of kit. So far it looks good, but it will be a while before i can have an opinion on the upload performance. Thank you for your time and effort.
B! - DiWaAspirantHi tarobun,
You provide exactly what I was looking for since super-poussin's Duo crashed.
just installed your 2.77 on top of super-poussin's 2.42. Some slight changes:
* json is not at the same place, just moved my existing one. As stated by metosx.
* didn't read "... then remember to save the torrent files somewhere else first." so I lost them, but not a big deal.
Reboot, now it's working fine
some few questions now:
* In your next versions will their be an upgrade process, or the new install will override everything (I'm concerned with settings.json ;) )?
* How can we disable the web interface? I guess it'll be a bit less CPU consumed. I use transmission-remote instead.
Thanks a lot for your very good work. - Mr_BGuide
Just don't use it, and it shouldn't affect performance. Admittedly tho, it's just a guess.DiWa wrote: * How can we disable the web interface? I guess it'll be a bit less CPU consumed. I use transmission-remote instead.
B! - tarobunTutor
* New versions will upgrade existing install so settings.json will not be lost. I've been upgrading since the first version so can say this works :)
* Not sure about disabling the web interface... Looks like no - "same web server that responds to RPC commands also serves the html/jpg/js/css files for the web server". - pugilaresAspirantHello guys, it's nice to hear that Transmission for SPARC ReadyNAS is goning on :-)
I still have 2.42 on my Duo and I think I'll be going towards 2.77.
Just one question - is transmission-create present there in 2.77?
In 2.42. there is. - tarobunTutor
In 2.42. there is.
Transmission-create is present in 2.77, but there is no web interface to it like in 2.42.
