yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help.
1. If you are in User or Domain security mode, and you don't have "public" or "guest" access enabled for the [media] share, you will need to specify a login and password to connect from the ReadyNAS Photos desktop software. The login and password should be what you would normally use to connect to the [media] share.
2. If you are in Share security mode, and you have a password set for the [media] share, when connecting from the ReadyNAS Photos desktop software, leave the login field blank, and enter the share password.
3. If you are in User or Domain security mode, and you are an account on the ReadyNAS with the same user name but a different password as what you are using on your PC, you will need to change the password to be the same.
4. Make sure [media] share has read/write privileges over CIFS.
5. If you have installed a pre-release version of RAIDiator that had ReadyNAS Photos support (shame on you since we never really released it ;-) ), and you're having problems with the READYNASPHOTOS database, you will need to remove the ReadyNAS Photos add-on, and re-install the add-on from here.
- mvengAspirantThough I used ReadyNAS Photos before, I have been unable to use recently.
When I log in after I input my user name and password (which are the same for the Media share), I get authenticated and then I get the following (with minor edits to protect privacy):
"Unable to connect to media/Pictures share on [correct address for the ReadyNAS...]"
When expanding the error message I get:
share=[hostname=[ReadyNAS address], share=media, folder=Pictures, username=[correct user name]], exit code=[17], error=[mount_smbfs: mount error: /Users/.../Dekoh/mnt/[username]55965979/media: File exists ]"
I tried to login as a different user and received the exact same message (with the different user name obviously).
I am using a macbook with ReadyNAS 600 with the RAIDiator 4.1.6 [1.00a147] and I already uninstalled and reinstalled the ReadyNAS Photos application and stopped and restarted the service on the NAS.
Any suggestions as to next steps? - minervaAspirantCan you send me in a private message the install.log thats in C:\Dekoh (win) ~/Dekoh (Mac) folder ?
- erlangerboysAspirantHi, Just recently installed a readynas duo. Have enabled the photo service and downloaded the desktop software. It get around 30% of performing the install and then exits with an error suggesting delete a folder and try again. The error being generated is identical to the posting on this thread from NOTSURE of 11 Feb 2009. I have made sure that all versions of the software and firmware are as advised on this site.
Cheers
Andy - beck2oldschoolAspirantNo
- k_3poAspirantHi Micheal,
For the browser on your desktop to connect to be able to connect to internet, do you need to enter set any proxy server?
/k-3po - beck2oldschoolAspirantHi minerwa,
when the check at "authentication neccesary" is not set, I get the message as written in first post.
When I set "authentication neccesary" and fill in the credentials of the NAS Admin I get the error message "A connection to ReadyNAS Photo Share is not neccessary, yet. Is the ReadyNAS Photo Service active? share=[hostname=192.168.100.33, share=Dekoh$, username=admin], exit code=[2], error=[Systemerror 2221. ]"
The Service is started ;-)
On the media share everyone has full access. All Subfolders has inherit the rights of the "media" share.
Michael - minervaAspirantHi Micheal,
Does the user you are connecting to ReadyNAS as, have read & write permissions in media share ?
Does user name or password have empty spaces or ':' or '@' ?
In both these cases, the above error message is shown. This will be rectified.
-minerva - beck2oldschoolAspirantHi @all,
I have RAIDiator 4.1.4 and ReadyNAS Photos 2.2 installed.
At this Site: http://localhost:81/readynas/template/index.jsp?pageId=settings I click on "connect". There are several messages.
"Authentication successfully"
"Configuration of ReadyNAS will be validated..."
and after a while: "By establishing a connection a problem has occured - Connection to readynasphotos.com must be possible. For the first connection to ReadyNAS, a Internetconnection is necessary"
It is possible to connect to readynasphotos.com from my localhost. I have no deny-messages in the firewalls logfile. The right standard Gateway is set on the readynas. Also the DNS server etc. When I try to look for new firmware, the readynas connect also to the internet, so I think the connection is of course possible.
What can be the problem?
Thanks in advance!
Michael - minervaAspirantHello mullinsworld:
Following is my answer to the similar question :
viewtopic.php?f=36&t=20605#p112984
Let me know if that helps.
-minerva - shumbiesAspirantHi mullinsworld,
Check the post before mine where minerva says
. If you click on the hyperlink contained under the word "here", you will be taken there. I had what I think is a similar issue to you and this cured my problem.Can you see if my reply to a previous posting here will help?
Hope this helps.
Cheers
shumbies
