yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help.
1. If you are in User or Domain security mode, and you don't have "public" or "guest" access enabled for the [media] share, you will need to specify a login and password to connect from the ReadyNAS Photos desktop software. The login and password should be what you would normally use to connect to the [media] share.
2. If you are in Share security mode, and you have a password set for the [media] share, when connecting from the ReadyNAS Photos desktop software, leave the login field blank, and enter the share password.
3. If you are in User or Domain security mode, and you are an account on the ReadyNAS with the same user name but a different password as what you are using on your PC, you will need to change the password to be the same.
4. Make sure [media] share has read/write privileges over CIFS.
5. If you have installed a pre-release version of RAIDiator that had ReadyNAS Photos support (shame on you since we never really released it ;-) ), and you're having problems with the READYNASPHOTOS database, you will need to remove the ReadyNAS Photos add-on, and re-install the add-on from here.
- kahunaAspirantOK, I just bought the ReadyNAS Duo v2. After spending hours trying to get invites to go out on photos, and after spending hours with support trying to get it to work,the support tech could not get Photos to send invites. He then told me it is a "known issue" and "many of these" don't work as they should with Photos II. Also, another "known issue": I can't upload files to readydrop on the web.
So, Netgear, here is my question: Do you think it is ethical to sell products that you actually know do not work? Here is the best part for me. I bought the unit from a store that is going to charge me a restocking fee. Thanks Netgear. - minervaAspirantCan you send me the ReadyNAS Photos desktop logs ? I am sending you instructions on how to do this.
Thanks
-minerva - mickselAspirantI am also using the Readynas NV+ in domain mode but in Win2008R2 mode. I am logged into my pc using my active directory user name and password and can access the \\NAS\media share. but when I try to connect with the readynas photos I get a Invalid credentials are Readynas Photos trying to access the share by \\IP\Media or by \\hostname\media, as you know the readynas in win2008r2 domain mode can't be access by IP, only hostname..
I'm wondering if this is my problem because I can't any account to work and can't try with a simple password (A-Z,a-z, 1-9) because of domain policy.
Any suggestions?
Modell: ReadyNAS NV+ [X-RAID]
Fast programvara: RAIDiator 4.1.8 [1.00a043]
Minne: 256 MB [2.5-3-3-7]
ReadyNAS Photos 2.2 - drjane1Aspiranthi there. I have a DUO. The RAIDar software and front end work fine, both disks synced and all is well. Then I tried to install ReadyNAS photos.....downloaded from the ReadyNAS photos site, double clicked and the installer started. After the progress bar reached about 95% it stopped and returned several Exception errors in Java. Install will not complete.
I tried to open the program but nothing happens, tried to uninstall from the Dekoh folder but it wont allow me to. Tried to download and install again but no joy. So I'm stuck with a useless partially installed program....any ideas bout how I can fix this issue? - gponchoAspirantHi I went to the Netgear website and downloaded the ReadyNas Photos II however everytime I try to install it under Update it does the first part (checking the file) then when I select Perform System update I get a error message "Invalid Checksum detected in the update file. Update aborted" can some one help?
- minervaAspirantHello All,
Our system has been upgraded and is up now. Can resume your works.
-Minerva - minervaAspirantHello All,
We are upgrading our system. Hence the system will be down the for next 1 hour. We shall notify our system's availability soon.
We regret for the inconvenience caused.
-Minerva - malarkyAspirantThanks for getting back Minerva.
I don't normally use RAIDar because I have a static IP for the ReadyNAS and I log into it regularly through the browser. But I installed RAIDar, it discovers the NAS straight away, locate button works, and set up works.
-Malarky. - minervaAspirantCan you download and run RAIDar and see if it can discover your ReadyNAS ?
http://www.readynas.com/?cat=41
Are you able to connect to your ReadyNAS using the Frontview ?
-Minerva - malarkyAspirantHi,
I'm having a problem that I can't find described on the forum.
I've got a Duo. I've installed the photos add-on. I've got an account at readynasphotos.com. I've installed the java software on my Ubuntu netbook and run it from /home/[user]/dekoh.sh.
It opens:
http://localhost:1025/readynas/template/index.jsp?pageId=settings
in Firefox 3.6.17. I login.
The 'discover' circle goes around a few times and it says 'No ReadyNAS device found'.
I can 'Add ReadyNAS host' at 10.1.1.200, with no credentials, or with credentials and it says 'invalid credentials'. I'm guessing that the invalid credentials are because it can't find the ReadyNAS, not because it has an issue with the credentials.
Any help on where I should start with this would be greatly appreciated.
