chuckster_l
Nov 06, 2016Aspirant
Disk Test Failure
I got a Disk Test Failure mail from my NAS (RN104, firmware 6.4.2): Disk test failed on disk in channel 2, model WDC_WD20EARX-00PASB0, serial WD-WMAZAYYYYXXX I'd like to know how severe my p...
mdgm-ntgr
Nov 06, 2016NETGEAR Employee Retired
The SMART stats look fine, so those don't explain why it failed the test.
chuckster_l
So where should I look at to find out my problem?
- mdgm-ntgrNov 07, 2016NETGEAR Employee Retired
What did the email you received say?
Well you could power down, remove the disk, hook it up to your PC and test it using WD Data LifeGuard Diagnostics.
- chuckster_lNov 07, 2016Aspirant
This is the email, with the serial hidden
Disk test failed on disk in channel 2, model WDC_WD20EARX-00PASB0, serial WD-WMAXXXXX4736.
I'd like to try other alternatives before running tests on HDD with the NAS with no redundancy or backup availables.
- StephenBNov 07, 2016Guru - Experienced User
And your smart results confirm that: Latest Self Test: Failed
What other alternatives? It seems to me that the only thing to do is to confirm if disk 2 is truly dead [or not].
Though it would be wise to make a backup.
