glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 <<
Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there!
6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000
>> EDIT <<
Here is how to fix fan and temperature issues on legacy x86 systems running OS 6.x, until built-in support is there.
I'd previously created this post http://www.readynas.com/forum/viewtopic.php?f=51&t=70133&start=255#p393886 but it will be easier for community to have fancontrol file examples for all models in a dedicated post.
It's a very easy and reliable method to monitor fan and temperature with lm-sensors and fancontrol standard packages.
No change on GUI reports.
NO WARRANTY / NO SUPPORT !!!
with root access, execute the following commands:
edit /etc/fancontrol file and copy the following file example corresponding to your model http://www.readynas.com/forum/viewtopic.php?f=51&t=71155#p395324
or create your own /etc/fancontrol file using pwmconfig command http://www.readynas.com/forum/viewtopic.php?f=51&t=71155&p=395324#p395318
fancontrol daemon start automaticaly when you install it.
restart fancontrol daemon for changes in file /etc/fancontrol take effect
to interact with fancontrol daemon, use
You can display sensors values with sensors command
>> EDIT <<
apt-get update && apt-get upgrade
apt-get install lm-sensors fancontrol
echo "#fancontrol" > /etc/fancontrol
/etc/init.d/fancontrol restart
/etc/init.d/fancontrol stop
/etc/init.d/fancontrol start
root@nas-xx-xx-xx:~# sensors
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +43.0°C (high = +80.0°C, crit = +100.0°C)
Core 1: +49.0°C (high = +80.0°C, crit = +100.0°C)
it8721-isa-0a10
in0: +12.19 V (min = +8.06 V, max = +10.66 V) ALARM
in1: +4.98 V (min = +2.20 V, max = +3.51 V) ALARM
in2: +3.28 V (min = +0.02 V, max = +0.18 V) ALARM
in3: +0.00 V (min = +0.00 V, max = +0.00 V) ALARM
in4: +1.02 V (min = +1.42 V, max = +2.21 V) ALARM
in5: +1.80 V (min = +1.66 V, max = +0.54 V) ALARM
in6: -12.10 V (min = -25.78 V, max = -0.01 V)
in7: +3.24 V (min = +0.00 V, max = +2.86 V) ALARM
in8: +3.34 V
fan1: 0 RPM (min = 10 RPM) ALARM
fan2: 0 RPM (min = 44 RPM) ALARM
fan3: 851 RPM (min = 11 RPM)
temp1: +0.0°C (low = +57.0°C, high = -25.0°C) ALARM sensor = thermistor
temp2: +0.1°C (low = -16.0°C, high = -123.0°C) ALARM sensor = thermal diode
temp3: +0.1°C (low = +37.0°C, high = -44.0°C) ALARM sensor = thermal diode
cpu0_vid: +2.050 V
- revinAspirantI've installed OS6 on a pro2. As I don't have fan speed and CPU temp, I've made a small script to generate my own RRD.
First, we have to generate the cpu RRD and Temp RRD. I've created on /dashboard/frontview/stats/rrdtool create fan.rrd --step 60 \
DS:rpm:GAUGE:120:0:5000 \
RRA:AVERAGE:0,5:1:2880 \
RRA:AVERAGE:0,5:30:384 \
RRA:AVERAGE:0,5:120:384 \
RRA:AVERAGE:0,5:1440:365 \
RRA:MAX:0,5:1:2880 \
RRA:MAX:0,5:30:384 \
RRA:MAX:0,5:120:384 \
RRA:MAX:0,5:1440:365 \
RRA:MIN:0,5:1:2880 \
RRA:MIN:0,5:30:384 \
RRA:MIN:0,5:120:384 \
and now CPU RRD:rrdtool create temp_sys.rrd --step 60 \
DS:core0:GAUGE:120:0:100 \
DS:core1:GAUGE:120:0:100 \
DS:system:GAUGE:120:0:100 \
Now it's time to create a script (update_rdd). This script gets temperature from CPU Core 0, CPU Core 1, System temperature and fan speed and updates de RRDs
#!/bin/sh
Coretemp1="/sys/devices/platform/coretemp.0/temp2_input"
Coretemp2="/sys/devices/platform/coretemp.0/temp3_input"
Systemp="/sys/devices/platform/it87.2576/temp2_input"
fan="/sys/devices/platform/it87.2576/fan1_input"
F=`cat $fan`
C1t=`cat $Coretemp1`
C1=`expr $C1t / 1000`
C2t=`cat $Coretemp2`
C2=`expr $C2t / 1000`
S=`cat $Systemp`
rrdtool update /frontview/dashboard/stats/temp_sys.rrd N:$C1:$C2:$S
rrdtool update /frontview/dashboard/stats/fan.rrd N:$F
##echo " CPU1=$C1 CPU2=$C2 SYS=$S "
So, We have the data on RRD. Now It's time to draw!. This example creates 2 simple PNGs from "now - 4 hours"rrdtool graph /frontview/dashboard/stats/tempsys.png --title="Temperature" --start end-4h \
--imgformat=PNG \
--width=500 \
--base=1000 \
--height=120 \
--interlaced \
DEF:a=/frontview/dashboard/stats/temp_sys.rrd:core0:AVERAGE \
DEF:b=/frontview/dashboard/stats/temp_sys.rrd:core1:AVERAGE \
DEF:c=/frontview/dashboard/stats/temp_sys.rrd:system:AVERAGE \
LINE1:a#800000:core0 \
LINE1:b#00FF00:core1 \
LINE1:c#FF0000:system \
COMMENT:"Comments"
rrdtool graph /frontview/dashboard/stats/fan.png --title="Fan" --start end-4h \
--imgformat=PNG \
--width=500 \
--base=1000 \
--height=120 \
--interlaced \
DEF:a=/frontview/dashboard/stats/fan.rrd:rpm:AVERAGE \
LINE1:a#800000:rpm \
COMMENT:"Comments"
The last step it's call those scripts from crontab:*/1 * * * * root /root/scripts/update_rrd
*/2 * * * * root /root/scripts/print_rrd
I've tried to change the images from original dashboard with this ones but it was much easier to generate a simple HTML and call this PNGs 8) - ATCISTutor
revin wrote: I've installed OS6 on a pro2. As I don't have fan speed and CPU temp, I've made a small script to generate my own RRD.
and now CPU RRD:
WOW revin! Your post above looks pretty cool. Any chance we could get a glimpse of your "Performance Tab" after you performed this hack? I'd be interested to see if I could do something similar on a Pro 6. . . - revinAspirantATCIS,
My images are really crapy :D. Here are an example:
But you really can make them as you want, simply playing a bit with rddtool graph (http://oss.oetiker.ch/rrdtool/doc/rrdgraph.en.html)
Here you have a few examples about what can you do with rrdtool : http://oss.oetiker.ch/rrdtool/gallery/ - F_L_TutorIs this fix still needed for the Ultra series?
I just upgraded and my fans/temp seems be ok. At least they are recognized in the dashboard.
Fan running a bit slow atm though (820 rpm)
CPU is 59/138 and System 44/111
System is idle except for re-sync - vin021079AspirantHi all,
I've just upgraded my Ultra 6 to 6.1.4. & having fan issues. i've followed all the instruction in the threads, but it doesn't work at all for me.
i've installed the lm-sensors & fancontrol, but giving me this error
Setting up fancontrol (1:3.3.4-1) ...
ln -s '/lib/systemd/system/fancontrol.service' '/etc/systemd/system/multi-user.target.wants/fancontrol.service'
[....] Restarting fancontrol (via systemctl): fancontrol.serviceJob failed. See system journal and 'systemctl status' for details.
failed!
invoke-rc.d: initscript fancontrol, action "restart" failed.
dpkg: error processing fancontrol (--configure):
subprocess installed post-installation script returned error exit status 1
Setting up lm-sensors (1:3.3.4-1) ...
ln -s '/lib/systemd/system/lm-sensors.service' '/etc/systemd/system/multi-user.target.wants/lm-sensors.service'
Errors were encountered while processing:
fancontrol
E: Sub-process /usr/bin/dpkg returned an error code (1)
& tried to setup the config using pwmconfig & got this error:
Current temperature readings are as follows:
cat: hwmon0/device/temp2_input: Resource temporarily unavailable
/usr/sbin/pwmconfig: line 892: let: S= / 1000: syntax error: operand expected (error token is "/ 1000")
cat: hwmon0/device/temp3_input: Resource temporarily unavailable
hwmon1/device/temp1_input 0
hwmon1/device/temp2_input 0
hwmon1/device/temp3_input 0
Any idea guys? i'm very desperate & my Ultra 6 fan now running on max 2300rpm. :(
Please help me. Thanks in advance - MueRAspirantI'll post my fancontrol config tonight (if I remember, I'm terrible at those things). It should work for you, but if the device is idle, frontview will report the CPU at -1°C / 30°F.
- sventunusAspirant
F.L. wrote: Is this fix still needed for the Ultra series?
F.L.: which Ultra do you own? I own an Ultra 6 and my fan still isn't recognized in the web UI ("fan dead" message). - F_L_Tutor
sventunus wrote: F.L. wrote: Is this fix still needed for the Ultra series?
I own an Ultra 4. Fan is still working here without any modification - sventunusAspirantAre you running a custom fancontrol/lm-sensors config? Would you care to post it here?
Curious about the difference between an Ultra 4 & an Ultra 6 concerning fans.
Thanks! - F_L_TutorNothing custom. I just upgraded to 6.1.4 and it was working out of the box.
If you still want any config please let me know where they are located.
