glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 <<
Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there!
6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000
>> EDIT <<
Here is how to fix fan and temperature issues on legacy x86 systems running OS 6.x, until built-in support is there.
I'd previously created this post http://www.readynas.com/forum/viewtopic.php?f=51&t=70133&start=255#p393886 but it will be easier for community to have fancontrol file examples for all models in a dedicated post.
It's a very easy and reliable method to monitor fan and temperature with lm-sensors and fancontrol standard packages.
No change on GUI reports.
NO WARRANTY / NO SUPPORT !!!
with root access, execute the following commands:
edit /etc/fancontrol file and copy the following file example corresponding to your model http://www.readynas.com/forum/viewtopic.php?f=51&t=71155#p395324
or create your own /etc/fancontrol file using pwmconfig command http://www.readynas.com/forum/viewtopic.php?f=51&t=71155&p=395324#p395318
fancontrol daemon start automaticaly when you install it.
restart fancontrol daemon for changes in file /etc/fancontrol take effect
to interact with fancontrol daemon, use
You can display sensors values with sensors command
>> EDIT <<
apt-get update && apt-get upgrade
apt-get install lm-sensors fancontrol
echo "#fancontrol" > /etc/fancontrol
/etc/init.d/fancontrol restart
/etc/init.d/fancontrol stop
/etc/init.d/fancontrol start
root@nas-xx-xx-xx:~# sensors
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +43.0°C (high = +80.0°C, crit = +100.0°C)
Core 1: +49.0°C (high = +80.0°C, crit = +100.0°C)
it8721-isa-0a10
in0: +12.19 V (min = +8.06 V, max = +10.66 V) ALARM
in1: +4.98 V (min = +2.20 V, max = +3.51 V) ALARM
in2: +3.28 V (min = +0.02 V, max = +0.18 V) ALARM
in3: +0.00 V (min = +0.00 V, max = +0.00 V) ALARM
in4: +1.02 V (min = +1.42 V, max = +2.21 V) ALARM
in5: +1.80 V (min = +1.66 V, max = +0.54 V) ALARM
in6: -12.10 V (min = -25.78 V, max = -0.01 V)
in7: +3.24 V (min = +0.00 V, max = +2.86 V) ALARM
in8: +3.34 V
fan1: 0 RPM (min = 10 RPM) ALARM
fan2: 0 RPM (min = 44 RPM) ALARM
fan3: 851 RPM (min = 11 RPM)
temp1: +0.0°C (low = +57.0°C, high = -25.0°C) ALARM sensor = thermistor
temp2: +0.1°C (low = -16.0°C, high = -123.0°C) ALARM sensor = thermal diode
temp3: +0.1°C (low = +37.0°C, high = -44.0°C) ALARM sensor = thermal diode
cpu0_vid: +2.050 V
- panosnlAspirant
I installed OS 6.5.0 which now has its own fancontrol in the NAS GUI. This sounded nice but the "quiet"setting is still too loud, much louder than when I was using fancontrol.
Now the fancontrol does not work anymre.
Any fixes to control the PWM settings of the new fancontrol?
- markwollGuide
I just did the 6.5.0 and the fan control is interesting at best.
It is reporting 10 fans. Fans 4-10 show zero rpm.
It is also showing temp1-temp6 with temp2,3,4 with -128C temps. Cool! to say the least.
The temps are ok, it just appears that sensors for non existant devices are active.
How do I tell the system to disregard the missing sensors?
- mdgm-ntgrNETGEAR Employee Retired
markwoll, which legacy model is this on?
- pelo88AspirantSo the warning seemed to be a flash in the pan. I've done nothing, not even a reboot, and the fan seems to be fine now.. Reporting running and in the green. So maybe it really did stop for a second? Should I still install fancontrol? I did turn off email alerts for the fan but can still see logs and such..
- petermacApprenticeOnly install the fancontrol if you need to.
- WingDogGuide
petermac wrote:
Only install the fancontrol if you need to.Hello.
can you provide additional config steps for fancontrol at 6.4.2? I'm new at linux.
I've got system fan 2220 RPM after one month powered-off device and now can't figure out how to fix this annoying noise!
tried update 6.4.1->6.4.2 but no luck.
thanks!
- pelo88AspirantOn 6.4.1 with a Pro6 that was factory defaulted a few days ago and today the cpu fan shows as dead tho the system temp is fine (obviously the cpu fan is running). What do I do?
- petermacApprenticeInstall the Fancontrol, if you have already installed that rerun the powerconfig program
- walshlinkLuminary
Installed an Intel Xeon X3230 in my ReadyNas Pro 6 ( RNDP6000-200 ) over the weekend with OS 6.4.0 installed. CPU temp runs around 48C. Fans and performance graphs seem to work just fine.
- ATCISTutor
walshlink wrote:Installed an Intel Xeon X3230 in my ReadyNas Pro 6 ( RNDP6000-200 ) over the weekend with OS 6.4.0 installed. CPU temp runs around 48C. Fans and performance graphs seem to work just fine.
Good for you! It seems that some of us who were running "fancontrol" from the early days of OS 6 are not so lucky. I have two Pro 6's. One that has been "Factory Default'ed" which works perfectly in every way, and one that has been running OS 6 from one of the very first versions that was capable of running on legacy hardware. That one is having this problem: https://community.netgear.com/t5/Using-your-ReadyNAS/Fan-CPU-in-enclosure-Internal-speed-is-below-threshold-after-FW/m-p/990867#U990867 ever since I upgraded to version 6.4
Me hopes this gets resolved in the next version. If not, it looks like I may have to start looking for a place to temporarily store 9 or 10 TB's of data, format, restore, rince, repeat. . . :smileyfrustrated:
- mdgm-ntgrNETGEAR Employee RetiredIt's quite a while since the previous post in the thread and things do change.
The fan speeds are set correctly on current OS6 firmware for all legacy x86 NAS. No need to do any hacks.
However do note that our support team supports running 4.2.x firmware on our legacy x86 products. If you do run OS6 on your legacy x86 NAS you can ask questions on the forums.
Synology also does not support upgrades to their latest OS series for legacy hardware that their users have pointed out is perfectly capable of running it.- viperhansaVirtuoso
and all:
I have my fan running at 888-900 and cpu temp 37C/99F & system 68C/154F...
Is there a way to increase the rpms so i get a bit of better cooling?
Or should i not be concerned about the temp levels? System has gone up to 72 and cpu have also been climbing.
In frontview only 1 fan is showing. Is that ok?
regards
Hans
- petermacApprenticeThe latest FW 6.4 seems to have broken the fan speeds on the old x86 hardware like the Pro series.
- pszilardAspirantGood to have someone offer assistance.
However as I have no idea on how to follow these steps, or even how to get root login, I think it really sucks that the manufacturer i.e. Netgear, doesn't fix this either in firmware or otherwise, without the user requiring to hack into root access and then invalidate warranty/support just to fix something that should not be a problem!
This is why I will never buy another ReadyNAS! Crap support! Good by Netgear, hello Synology. - mdgm-ntgrNETGEAR Employee RetiredIt is hard coded as to where to look for temps and what fan(s) to control.
- tijgertGuideI noticed that on Ultra 6's there's an extra (unused) fan header that gives RPM indication when a fan is hooked up to it.
Is that fan then controlled or does the software *know* the Ultra 6 only came with 1 fan and thus ignores the other fan indication i.e. doesn't spool up or down with temps? - mdgm-ntgrNETGEAR Employee RetiredThe fans are controlled using readynasd, software written by our engineering team.
- mrQQApprenticeWhen you say 6.1.7, does it mean, that it has same lm-sensors and fancontrol packages preinstalled, or how does it control them?
