michelefaccini
Oct 01, 2011Aspirant
Error establishing a database connection
Hi,I get this error when I try to execute Wordpress install.php to complete the installation.
Possible causes :
Are you sure you have the correct username and password?
Are you sure that you have typed the correct hostname?
Are you sure that the database server is running?
I do have access to my database server because I can from phpMyadm do what I want....
Any idea ?
Here's my wp-config.php
// ** MySQL settings - You can get this info from your web host ** //
/** The name of the database for WordPress */
define('DB_NAME', 'wordpress');
/** MySQL database username */
define('DB_USER', 'wordpress');
/** MySQL database password */
define('DB_PASSWORD', 'mypassword');
/** MySQL hostname */
define('DB_HOST', 'localhost');
/** Database Charset to use in creating database tables. */
define('DB_CHARSET', 'utf8');
/** The Database Collate type. Don't change this if in doubt. */
define('DB_COLLATE', '');
* Authentication Unique Keys and Salts.
* Change these to different unique phrases!
* You can generate these using the {@link https://api.wordpress.org/secret-key/1.1/salt/ WordPress.org secret-key service}
* You can change these at any point in time to invalidate all existing cookies. This will force all users to have to log in again.
* @since 2.6.0
define('AUTH_KEY', 'put your unique phrase here');
define('SECURE_AUTH_KEY', 'put your unique phrase here');
define('LOGGED_IN_KEY', 'put your unique phrase here');
define('NONCE_KEY', 'put your unique phrase here');
define('AUTH_SALT', 'put your unique phrase here');
define('SECURE_AUTH_SALT', 'put your unique phrase here');
define('LOGGED_IN_SALT', 'put your unique phrase here');
define('NONCE_SALT', 'put your unique phrase here');
* WordPress Database Table prefix.
* You can have multiple installations in one database if you give each a unique
* prefix. Only numbers, letters, and underscores please!
$table_prefix = 'wp_';
* WordPress Localized Language, defaults to English.
* Change this to localize WordPress. A corresponding MO file for the chosen
* language must be installed to wp-content/languages. For example, install
* de_DE.mo to wp-content/languages and set WPLANG to 'de_DE' to enable German
* language support.
define('WPLANG', '');
* For developers: WordPress debugging mode.
* Change this to true to enable the display of notices during development.
* It is strongly recommended that plugin and theme developers use WP_DEBUG
* in their development environments.
define('WP_DEBUG', false);
/* That's all, stop editing! Happy blogging. */
/** Absolute path to the WordPress directory. */
if ( !defined('ABSPATH') )
define('ABSPATH', dirname(__FILE__) . '/');
/** Sets up WordPress vars and included files. */
require_once(ABSPATH . 'wp-settings.php');
Possible causes :
Any idea ?
* @since 2.6.0
* language support.
- michelefacciniAspirantG O T I T...From phpMyadm I edited wordpress SQL user's from localhost to % (which stands for any host)......
- polderviolinAspirantHi Michelefaccini
It seems that I have semilars problems....
so please explain the last words(the GOT IT sentence):
- form phpMyadm ..is this in the php-config, or wich PHP / info file
- did you replace the 'localhost' in %
Maybe a picture of the file can tell a thousand words...
Thanks
polderviolin - michelefacciniAspirantDo you have access to your phpMyadmin ?
- polderviolinAspirantHi,
Anwer:
Directly after installation (and configure phpmy.. hostname nas-ip,socketadress, uid/pw mysql) I could login in PHPADMIN (and create a db) after that login by PHPMYADMIN fails: Error 1045.
So the problem:
- login by phpmyadmin (start in windows/frontview) comes with error 1045
- login db readynasphotos by MySQL ADMINISTRATION comes with error 1045
Further info for now:
! I'm able to access mysql by putty in SSH (and also there create a db)
! with "MYSQL Aministration" and "SQL Lite Manager" (both alternative for PHPMYADMIM) I can access the Wordpress database but not the other databases gives also error 1045
! I have already reinstalled php5 (5.3.8) + PHPMYADMIN (3.4.5)...change mysql pw to be sure that phpmyadmin use the same...
So I tried for a month to get phpadmin up & running (for wordpress) and I really need a helping hand/brain...... - michelefacciniAspirantYou wrote 'So the problem:
- login by phpmyadmin (start in windows/frontview) comes with error 1045...'
What do you mean by 'start in windows/frontview' ? You have to access you phpMyadmin from your web browser http://your NAS ip address/phpadm/.
From there you should set up permissions over the databases. - michelefacciniAspirantOtherwise you could grant permissions over databases accessing the nas with the putty shell....
Here's my 'config.inc.php' :
/* Servers configuration */
$i = 0;
/* Server: localhost [1] */
$i++;
$cfg['Servers'][$i]['verbose'] = '';
$cfg['Servers'][$i]['host'] = 'localhost';
$cfg['Servers'][$i]['port'] = '';
$cfg['Servers'][$i]['socket'] = '/var/run/mysqld/mysqld.sock';
$cfg['Servers'][$i]['connect_type'] = 'socket';
$cfg['Servers'][$i]['extension'] = 'mysqli';
$cfg['Servers'][$i]['auth_type'] = 'config';
$cfg['Servers'][$i]['user'] = 'root';
$cfg['Servers'][$i]['password'] = 'put here your password';
/* End of servers configuration */
$cfg['DefaultLang'] = 'en-utf-8';
$cfg['ServerDefault'] = 1;
$cfg['UploadDir'] = '';
$cfg['SaveDir'] = '';
Here's my 'my.cnf' file :
[client]
port = 3306
socket = /var/run/mysqld/mysqld.sock
[mysqld_safe]
nice = 0
[mysqld]
# * Basic Settings
user = admin
pid-file = /var/run/mysqld/mysqld.pid
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
language = /usr/share/mysql/english
skip-external-locking
skip-name-resolve
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
# bind-address = 127.0.0.1
skip-networking
innodb_buffer_pool_size = 6M
key_buffer_size = 16k
myisam_sort_buffer_size = 16k
max_connection = 20
# * Fine Tuning
key_buffer = 16k
max_allowed_packet = 16M
thread_stack = 128K
# * Query Cache Configuration
query_cache_limit = 1048576
query_cache_size = 32768
query_cache_type = 1
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
#log = /var/log/mysql.log
#log = /var/log/mysql/mysql.log
# The following can be used as easy to replay backup logs or for replication.
#server-id = 1
#log-bin = /var/log/mysql/mysql-bin.log
# See /etc/mysql/debian-log-rotate.conf for the number of files kept.
max_binlog_size = 16384
#binlog-do-db = include_database_name
#binlog-ignore-db = include_database_name
skip-bdb
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash # faster start of mysql but no tab completition
[isamchk]
key_buffer = 16M
