- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SRX5308 WAN gets a public IP with auto detect
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi!
maybe this is a silly question but i am new on this.
We have a ISP router set on DMZ bridge on port 4, from this port a connection to WAN port on SRX5308. The address of the ISP router is 192.168.0.10 (public is 211.......). I sat the ip for WAN to 192.168.0.2, sub 255.255.255.0 and gateway address 192.168.0.10. The internet led is amber but i have no internet connection from the LAN side of the SRX5308. I can ping on diagnostics from the LAN side to the WAN ip but not to the ISP router ip.
the status of WAN is connected.
I tried to use the auto detect instead on WAN port but I got an IP of range 90.xxx.xxx.xxx instead of a 192.168.0.XXX
Is there something that i am missunderstanding? shouldnt i get an ip of range 192.168.0.XXX if i use auto detect?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: SRX5308 WAN gets a public IP with auto detect
Welcome to our community! 🙂
Definitely, once you assign the WAN port as auto-detect, then it will send a request in order to be acknowledged by the DHCP server. You really cannot ping an IP from ISP as this is disabled by default of the SRX5308. You may try to enable ping request on Security > Firewall > Attack Checks - Respond to ping on Internet ports - Enable.
John
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a pc connecred directly on the ISP and its getting the right ip adress, perhaps the bridge mode is not working properly?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it still getting a private IP then the ISP router is not properly set to bridge mode. Have you tried to statically assign an IP on the WAN port?
John
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried to assign static a private Ip address but it didnt work. LAN side has not connection to internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
May you be able to show us your network topology? So we can understand better what seems to be the issue.
John
