Orbi WiFi 7 RBE973
Reply
2 vlans GS748T to 2 vlans GS724TP lock nwrk conns
1PAUL1
Novice
I don’t post too often but just recently bought some new hardware that is not playing well sssooo. Reviewing forum post did not readily find a similar instance. Here are the problems right up front.
1) Losing access to switch and network connections when 2 VLANS are the connected to 2nd set of VLANS on 2nd switch.
2) During troubleshooting the prior issue, made all GS724TP ports part of PVID 4 and 5 thus removing from PVID1. Now no web access since PVID1 was mgmt PVID (at least I believe this to be the cause)
Presently have router FVS318v3 feeding a switch GS748T v4 then connection via fiber to switch GS724TP in another building. Vlans are arrange for 748T ports VLAN 1 (corp VLAN PVID1) and VLAN2 1 (wifi PVID5) with 1 router port common to both. The 724TP has similar vlan sets using separate fiber to connect between the two. No Trunking, no LAG, no SPT, no Multicast, etc. most other settings are default.
Configuration:
Router FVS318v3 1 port member of both VLANs, single port being used.
GS748T:
Vlan4
PVID1
corporate vlan
untagged port members except for VLAN5 members
GBIC AGM731F on port 50 (goes to 724TP port 23 GBIC)
VLAN5
PVID5
Free WiFi
untagged port members 1-8 and port 49
GBIC AGM731F on port 49 (goes to 724TP port 24 GBIC)
GS724TP
Vlan4
PVID4
corporate vlan
GBIC AGM731F on port 23
VLAN5
PVID5
Free WiFi
untagged port members 1-8 and port 24
GBIC AGM731F on port 24
ASCI diagram:
FVS318  GS748T VLAN1 fiber port50  fiber port 23 PVID4 GS724TP  corp network
GS748T VLAN2 fiber port 49  fiber port 24 PVID5 GS724TP  Free WiFi
With the above configuration plugging in 1 fiber at a time, works fine. When both are plugged in, all network lights begin flashing @ same rate (2X per second) and all network connectivity is lost. Removing one fiber stops the fast flashing, normal flashing comes back and network connectivity is restored.
A) How can 2 VLANs be replicated using the GS724TP switch in the other building?
B) How can control be re-established with the GS724TP without reset to factory defaults? Although switch is working; cannot ping, cannot see in Smart Control Center, does not show up in 748T mac address table.
Thanks in advance for any insight.
Paul.
Message 1 of 7
1PAUL1
Novice
Re: 2 vlans GS748T to 2 vlans GS724TP lock nwrk conns
Lots of views but no replys. Need more info?
I can certainly provide.
Paul
Message 2 of 7
adit
Mentor
Diagram it.
Message 3 of 7
Daedalus01
Sounds like a loop is in there somewhere. Having routers or switches plugged into each other twice causes routing loops meaning all the lights start flashing and network connectivity is lost. I agree with Adit, need a diagram
Message 4 of 7
1PAUL1
Novice
Certainly is a loop but figured the separate vlans would prevent circular traffic. Will post diagram showing loop separated into distinct VLANs.
Paul
Message 5 of 7
1PAUL1
Novice
Here is diagram and original 2nd question needing to be answered:
2) How can control be re-established with the GS724TP without reset to factory defaults? Although switch is working; cannot ping, cannot see in Smart Control Center, does not show up in 748T mac address table. PVID 1 changed to PVID 4 and 5 for all ports. PVID1 may have been the mgmt PVID
Gs748t is one switch and GS724tp 2nd switch; connected with 2 fiber GBICs.
Router FVS318v3--|---GS748T VLAN1
| fiberport50-|
| +ports12345 |----Nwk1
| fiberport23
| GS724tp
| VLAN1
| ports12345-----------NWk1
| GS724tp same switch
| GS724tp same switch
| GS724tp same switch
| GS724tp same switch
| GS724tp same switch
| Ports6789-------------Nwk2
| VLAN2
| GS724tp
| fiberport24
| fiberport49-|
| +ports16789 |-----Nwk2
|---GS748T VLAN2 |
Message 6 of 7
1PAUL1
Novice
diagram formatting being stripped away.
Here is next attempt using @ as a format place holder. Pls ignore all @.
Router@FVS318v3--|------------GS748T VLAN1
@@@@@@@@@@@@@@@@@|@@@@@@@@@@@@ports1,2,3,4,5
@@@@@@@@@@@@@@@@@|@@@@@@@@@@@@+fiberport50
@@@@@@@@@@@@@@@@@|@@@@@@@@@@@@@@@GS724tp
@@@@@@@@@@@@@@@@@|@@@@@@@@@@@@@@@VLAN1
@@@@@@@@@@@@@@@@@|@@@@@@@@@@@@@@fiberport23
@@@@@@@@@@@@@@@@@|@@@@@@@@@@@@@@+ports1,2,3,4,5----NWk1
@@@@@@@@@@@@@@@@@|@@@@@@@@@@GS724tp same switch
@@@@@@@@@@@@@@@@@|@@@@@@@@@@@@@@+ports6,7,8,9------WiFi
@@@@@@@@@@@@@@@@@|@@@@@@@@@@@@@@fiberport24
@@@@@@@@@@@@@@@@@|@@@@@@@@@@@@@@@VLAN2
@@@@@@@@@@@@@@@@@|@@@@@@@@@@@@@+fiberport49
@@@@@@@@@@@@@@@@@|@@@@@@@@@@@@@@ports1,6,7,8,9
@@@@@@@@@@@@@@@@@|--------------GS748T@VLAN2
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 12890 views
  • 0 kudos
  • 3 in conversation
Announcements
