rdraper's avatar
rdraper
Follower
May 17, 2016
FS726T Unable to upgrade Firmware
I have an FS726T that i'm struggling to upgrade firmware on, its still on V1.2.3_02 so needs updating in Smartwizard Discovery Utiltiy and not Smart Control Center software, i can not find a copy of it anywhere, any ideas..?
Thanks
  • Retired_Member's avatar
    Retired_Member
    FS726T is a Smart Switch with a Web Interface. You should be able to connect to the web GUI and upgrade the F/W from there. The use of the utility is not mandatory for Smart switches.
    If you really want the old utility, go to http://downloadcenter.netgear.com/ and search for FS726TP. This one has the link.
    • JohnRo's avatar
      JohnRo
      NETGEAR Employee Retired
      Hello rdraper,
      Welcome to the community!
      Here's an old copy of SmartWizard version 2.05.05, see if it works. Retired_Member' suggestion is also very helpful if the utilities will not work.
      Let us know what happens.
      Thanks,
    • JohnRo's avatar
      JohnRo
      Hi rdraper,
      We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
      If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
      Thanks,
ProSupport for Business
