somnus1654's avatar
somnus1654
GS105Ev2 logon access
Hi, im just  buy 2 of this switches to improve vlans for practice.
I reboot the switches holding the reset button in the back side.
It look like the reboot apply well, all the leds turn in for 2 seconds, etc.
i download the prosafe utility and i try to use the defalt password (is in the label in the switch, in this casa password)
i can log in, i try by the webserver api, but i can do it.
i try admin,password, but can log in
any ideas?
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi somnus1654,
    Welcome to our community!
    Basically, the default password is password. If it is not working, please try to download the latest version of the Prosafe utility.
    You may download it here.
    • somnus1654's avatar
      somnus1654
      hi, the new version when y tried to login, ask me for username and password, i use as username: admin and for password:password.
      Can´t log in
      i have 2 of this switches, both have the same problem.
      i try the password 1234 and admin admin, and i can't login
      • JohnC_V's avatar
        JohnC_V
        somnus1654,
        Try pressing and holding the reset button for about 10-15 seconds, then reboot. I believe this is a brand new unit, you may also open a chat / case online on NETGEAR support and please let them know the status of your switch.
ProSupport for Business
