melucas's avatar
melucas
GS108Tv2 SNTP timeout
My GS108Tv2 will not connect to any SNTP servers to sync the device's time.  I have tried many different dns names for North America.  All of the status eventually show "Request Timed Out".
I can ping the DNS names (e.g. time.chu.nrc.ca, time.nrc.ca, pool.ntp.org, etc)
I have also tried the same server which my firewall is configured to use (0.peplink.pool.ntp.org)
I updated the firmware to v5.4.2.36 but have the same result.
This post did not help me resolve my issue.
Any suggestions on how to resolve this?
Thank you,
Michael
  • schumaku's avatar
    schumaku
    Double check default gateway and DNS.
    Try ca.pool.ntp.org or to exclue DNS from the equation e.g. 205.206.70.40: (one of the Canada pool.ntp.org for example).
    • melucas's avatar
      melucas
      Thank you for your response.
      The lookup works with an ip address as you suggested.
      I tried changing the DNS settings to use Google's servers.  However, using the DNS names still fail with a timeout.
      Anything else to try to get the DNS names to resolve?
ProSupport for Business
