Drekko's avatar
Drekko
JGS516PE during hot days
Hey guys
Im wanting to buy a POE switch. I want to store it in a mounted switch cabinet in my garage. As I dont have much spare space inside
The problem though is the garage gets pretty hot in summer hot days. If the garage hits about 45 degrees how do you think the switch will cope if it is in a switch cabinet with some exhaust fans?
  • XavierLL's avatar
    XavierLL
    NETGEAR Employee Retired
    Hi Drekko,
    Welcome to our community!
    The JGS516PE has been designed to operate at a maximum of 50C degrees celsius, see below the datasheet:
    http://www.downloads.netgear.com/files/GDC/datasheet/en/ProSAFE_Web_Managed_Switches_DS.pdf
    Considering your environment adding exhaust fans to your cabinet definetly will help, moreover please consider improving your air flow in your garage to stay below the 50C.
    Hope it Helps!
    Xavier Lleixa
    NETGEAR CBU PLM
    • Drekko's avatar
      Drekko
      Thanks very much
      for some reason I thought it was 0 to 40 degrees C?
      I definently read that somewhere..
      What happens if the room is 55 degress? :)
      • XavierLL's avatar
        XavierLL
        Hi Drekko,
        I double checked in our internal specs and I can confirm that 0-50C if you remember where you saw 0-40 please let us know and we will modify it :)
        Xavier Lleixa
        NETGEAR CBU PLM
    • Drekko's avatar
      Drekko
      Sorry one more question does this have 1 internal fan ? Where does the fan exahust the hot air out because I cannot see any ventilation on the unit?
      • XavierLL's avatar
        XavierLL
        HI Drekko,
        Yes it has an internal Fan and ventilation air holes on the side, see pictures below :
        Xavier Lleixa
        NETGEAR CBU PLM
ProSupport for Business
