Orbi WiFi 7 RBE973
Reply
M4300 trying to rest ip http port number to default port 80
CrustySparks
Tutor
Trying to reset the http port back to default 80 from 6535:
my startup-config ... partial ...
exit
ip http port 6535 <---
ip http secure-server
ip http secure-protocol TLS1
ip ssh server enable
CLI manual says:
no ip http port
Switch says:
(M4300-12X12F) (Config)#no ip http ?
                                                         accounting Configure an Accounting List.
                                                         authentication Configure an Authentication List.
(M4300-12X12F) #show version
Switch: 1
System Description............................. M4300-12X12F ProSAFE 12-port 10GBASE-T and 12-port 10G SFP+, 12.0.2.20, 1.0.0.9
Machine Model.................................. M4300-12X12F
Serial Number.................................. 4G43697E80107
Burned In MAC Address.......................... 10:DA:43:F9:47:91
Software Version............................... 12.0.2.20
CPLD version................................... 0x5
Bootcode Version............................... 1.0.0.9
Current Time................................... Jan 16 09:53:40 2018 (UTC-8:00)
Current SNTP Sync Status....................... Success
(M4300-12X12F) (Config)#show ip http
HTTP Mode (Unsecure)........................... Enabled
HTTP Port...................................... 6535
Maximum Allowable HTTP Sessions................ 16
HTTP Session Hard Timeout...................... 24 hours
HTTP Session Soft Timeout...................... 15 minutes
HTTP Mode (Secure)............................. Enabled
Secure Port.................................... 443
Secure Protocol Level(s)....................... TLS1 -----
Maximum Allowable HTTPS Sessions............... 16
HTTPS session hard timeout..................... 24 hours
HTTPS session soft timeout..................... 15 minutes
Certificate Present............................ True
Certificate Generation In Progress............. False
(M4300-12X12F) (Config)#show captive-portal
Administrative Mode............................ Disable
Operational Status............................. Disabled
Disable Reason................................. Administrator Disabled
CP IP Address.................................. 0.0.0.0
Message 1 of 9
Accepted Solutions
Hopchen
Prodigy
Re: M4300 trying to reset ip http port number to default port 80
Hi @CrustySparks,
The issue is that you are doing this from the global config mode. You need to do it from EXEC mode, not config mode 🙂
As this:
(M4300) >enable
(M4300) #ip http server
(M4300) #ip http port 80
Cheers
Message 6 of 9
All Replies
schumaku
Guru
Re: M4300 trying to rest ip http port number to default port 80
Dunno why the documented "no ip http port" does not work, no switch at hand, try this:
no ip http server
ip http server
ip http port 80
Message 2 of 9
CrustySparks
Tutor
(M4300-12X12F) (Config)#no ip http server
% Invalid input detected at '^' marker.
Message 3 of 9
schumaku
Guru
...continue with the other commands, regardless...
Message 4 of 9
CrustySparks
Tutor
(M4300-12X12F) #config
(M4300-12X12F) (Config)#ip http server
(M4300-12X12F) (Config)#ip http port 80
I'm guessing that I'll have to modify the startup config and edit out the offending line and restart the switch because it seems to be innacessible from the command line.  If you look at the top part of the startup you see that it comes before the configure command:
serviceport protocol none
serviceport ip 10.10.10.1 255.255.255.0 0.0.0.0
no serviceport ipv6 enable
vlan database
vlan 2-6
vlan name 2 "admin"
vlan name 3 "WiFi"
vlan name 4 "stdnt"
vlan name 5 "mgnt"
vlan name 6 "voip"
no vlan routing 1
vlan routing 4 1
vlan routing 3 2
vlan routing 5 3
vlan routing 2 4
vlan routing 6 5
exit
ip http port 6535
configure
sntp server "172.16.0.2"
clock timezone -8 minutes 0
stack
member 1 5
exit
& etc ....
That option used to be available on the System Management Tab in the config pages.
Message 5 of 9
Hopchen
Prodigy
Hi @CrustySparks,
As this:
(M4300) >enable
Cheers
Message 6 of 9
CrustySparks
Tutor
Ahem ... Smiley Embarassed ... thank you.  That was it ... I think too much of a Cisco hangover ... Smiley Surprised
Message 7 of 9
schumaku
Guru
Based on the # prompt I've assumed you are in config mode. Silly me 8-)
Message 8 of 9
CrustySparks
Tutor
Been there ... done that ... Smiley Frustrated
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 4620 views
  • 2 kudos
  • 3 in conversation
Announcements
