Orbi WiFi 7 RBE973
Reply
changing auto-voip type broke stack
robfantini
I had a stack of two of these:
!System Description "GSM7352Sv2 48-Port Gigabit Layer 3 Stackable Managed Switch with 2 10G SFP+ port, 10.0.0.53, 01.00.35"
!System Software Version "10.0.0.53"
early today I set up   '  auto-voip vlan '
after trying to switch to  'auto-voip protocol-based'    the stack froze.
after power reset  the former master unit   has  no  link lites lit.
the former  secondary is runnig OK as master.
from prosafe web page ,  the bad switch is seen.    some of the vlan tags are not what they are supposed to  be [  some  T's changed to U ]
Does someone have a suggestion to fix the broken unit?
Model: GSM7352Sv2|ProSAFE 48-port Managed L3 Gigabit Stackable Switch
Message 1 of 10
Accepted Solutions
robfantini
Re: changing auto-voip type broke stack
tech support by email told me how to solve this.
from cli:  reload
As expected  the switched restarted so office was ready for that.
Message 10 of 10
All Replies
robfantini
More info:
before changing the auto-vlan type , I had saved the running config to start up , along with saving the text settings to tftp.
the one remaining switch is running good  - all vlans report working phones, printers and workstations.
ALSO from  java/web device view  - Back of switch :   Only the working switch  shows a stack connection slot green.    Power and serial are green on both
Message 2 of 10
Retired_Member
Not applicable
Hi robfantini,
Welcome to the community! Smiley Happy
Could you please answer below quesitons, we need more detailed information for further analysis:
1. What's the auto-voip VLAN ID? Is it a new created VLAN or exsit VLAN?
2. Could you provide the auto-voip CLI command that you execute?
3. It's will be better if you can provide us the configuraiton of the Switch.
How do I send configure files from my Managed Switch to NETGEAR community moderators?
http://kb.netgear.com/app/answers/detail/a_id/31439
EricZ
NETGEAR Employee
Message 3 of 10
robfantini
   I am now using  'protocol based'  .  there is no vlan setting needed for that.
no auto-voip vlan
 I'll send the config file next.
Message 4 of 10
Retired_Member
Not applicable
Hi robfantini,
Thanks for your immediately response.
Could you please also send us the tech-support file at the same time with the configuration file. We can check the detailed information for the freezing Unit.
Message 5 of 10
robfantini
1- I sent the startup-config in an email.
2- another thing I did after the two cli commands,   from web page at OUI Port Settings - I disabled Auto VoIP Mode  for all ports.
Message 6 of 10
robfantini
I am unable to generate a tech support file.
I get this error:   Error! File is either empty or not found.
I tried http and tftp .
 Is there another way to create the file?
Message 7 of 10
Retired_Member
Not applicable
Hi robfantini,
You need execute command as 'show tech-support' by CLI mode(console port or telnet) at first, it will generate tech-support file.
Message 8 of 10
robfantini
OK  sent another email with 'TechSupport'
and
the startup-config a few hours before I changed auto-voip mode.
Message 9 of 10
robfantini
from cli:  reload
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3858 views
  • 0 kudos
  • 2 in conversation
Announcements
