- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Can't Update firmware of my Netgear MR1100
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't Update firmware of my Netgear MR1100
Hi windofage,
I will work with you through PM for further assistance. :]
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did U find solution for me.
Note:
Telecommunications company: Ooredoo
Model: MR1100
Firmware: NTG9XNTG9X50C_10.12.02.01
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Mored1984,
Have you done a factory reset and then tried "checking for update"? Have you reseat your SIM card?
Please let me know. :]
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Already did four times but still can't update (Even can't manually update due not available "Choose file" button)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Mored1984,
Thank you for your response. I will PM you for further assistance on this. :]
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the solution. I am from Malaysia with local simcard and unable to update the firmware, and no manul upgrade option available with existing old firmware. I just change the APN back to default telstra.internet, reboot the router and it can now detect the firmware upgrade.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi iieeann,
I will be PMing you for further assistance. :]
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
im in malaysia and still can't update and router homepage no manual update firmware..My router use firmware version NT9GX50C_10.12.02.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
How could I upgrade my device...
Information:
Hardware Version: 1.0
PRI Version: 01.16
Firmware Version: NTG9X50C_10.12.02.01
Firmware Build Date: 2017/01/28
- Mark as New
- Bookmark
- Subscribe
- Permalink
hello jason ,
i m from malaysia ...i also have a problem in upgrading the firmware...
It seems all 3 options doesn't work for me.
Option1: App gives me an error dialog after I click "CHECK FOR UPDATES"
Option2: There is no manual upload option cause my firmware is old.
Option3: The blue button freezes at "CHECKING..." after I click "CHECK FOR UPDATES
even i follow some malaysia user which use celcom simcard with xox apn , still the same which cannot update the firmware...do you mind to help me update the firmware through the OTA...
i have attach together with the screenshot of my device info for you in order for the upgrading the firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Everyone,
If you're still having this issue then please PM me with firmware // PRI // Sku // which provider model your M1 is // etc. to me.
What troubleshooting have you done?
Please provide your contact information.
Please be detailed as I will be forwarding this to my internal team for further assistance. :]
Thank you. :]
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is my Netgear M1 info from the app
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi i am from malaysia also cant update new firmware ....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello everybody,
Could sombody advice any solution for updating firmware from NTG9X50C_10.12.02.01 up to latest version for Unlocked Telstra Nighthawk M1 (MR1100)?
(rebooting, default APN, factory reset no have any effect)
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@dr_livsi2004 This was a bug the M1 had and from memory it was that version of firmware you have. If your M1 doesn't find the new firmware and update when you click the update firmware button under settings, then you will need to PM one of the netgear employees(maybe @JasonN) here. They will guide you from there on how to manually update the M1. Make sure your battery is charged when you do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Keep trying to update it, it will eventually find the update and allow you to launch the process.
- Mark as New
- Bookmark
- Subscribe
- Permalink
P.S. if someone has same problem I can help, but for the for devices with same firmware version as my.
- « Previous
- Next »
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
