Orbi WiFi 7 RBE973
Reply
R7000NETGEAR Armor security activation process failed due to some reason.
SlayAnimosity
Follower
The NETGEAR Armor security activation process failed due to some reason.
Please contact Technical Support for more details. Not sure what the issue is.
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 16
Christian_R
NETGEAR Employee Retired
Re: R7000NETGEAR Armor security activation process failed due to some reason.
Hello @SlayAnimosity
Are you experiencing this issue via App? If so, which App?
~Christian
Message 2 of 16
badhand386
I too am having this issue.
Model: R7000|AC1900 Smart WIFI Router
Message 3 of 16
DexterJB
NETGEAR Moderator
Hi @badhand386,
Please make sure the steps on the link below are followed.
https://kb.netgear.com/000060247/How-do-I-activate-my-NETGEAR-Armor-subscription-using-my-activation...
Dexter
Community Team
Message 4 of 16
badhand386
I followed all of those steps before multiple times and nothing happened. I don’t even have the activation code anymore because I discarded it due to inability to use it and there isn’t an option to purchase it outright (which is what I want to do).
Message 5 of 16
DexterJB
NETGEAR Moderator
Hi @badhand386,
I have sent you a message. Please check your inbox.
Dexter
Community Team
Message 6 of 16
Beetle02
I'm having the same problem with my R7000P router.  If I try it from the browser I get the message "The NETGEAR Armor security activation process failed due to some reason".  If I try it from the app I get the message "Process is taking too long (more than 60 secs), Try again".
Message 7 of 16
DexterJB
NETGEAR Moderator
Hi @Beetle02,
1. What is the firmware version of the router?
2. What is the Android version of your device?
3. Have you tried using another device (another Android, iOS) with the app installed?
Dexter
Community Team
Message 8 of 16
Beetle02
V1.3.1.44_10.1.23
I am using an iPhone 10 with iOS 12.1.3
I tried it on my iPad and got the same results, 60 second time out.
One other thing I noticed this morning, when I log into my netgear account my router is listed as one of my devices.  But if I go to armor.netgear.com and log into my netgear account it says no routers associated with this account.
Thanks
Message 9 of 16
DexterJB
NETGEAR Moderator
Hi @Beetle02,
Dexter
Community Team
Message 10 of 16
Denali94
Dexter - I am having the same issues as described above.  Spent 3 hours on phone with Netgear Tech Services today and after the 9th time of changing passwords I realized they did not have a clue. I love my router and am a huge fan of Bitdefender - would love to have the Armor program in place for the additional protection.
Any help you can extend would be appreciated.
Message 11 of 16
DexterJB
NETGEAR Moderator
Hi @Denali94,
Dexter
Community Team
Message 12 of 16
Hi @DexterJB,
I am also having the same problem as mentioned in OP. It just started after updating the Firmware to the latest version. I am able to sign in to my Armor account but once it begins activating it hangs for a minute or two and fails.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 13 of 16
DexterJB
NETGEAR Moderator
Hi @ChemicalGilroy,
Welcome to the community!
If you haven't yet, we recommend doing a factory reset on the router and see if the issue will persist. This link may help out for the reset process. Once you've completed that, try logging out and logging back to your Armor app. Let us know how it goes.
Dexter
Message 14 of 16
@DexterJB  This did the trick! Thanks!
Message 15 of 16
DexterJB
NETGEAR Moderator
Cool! Glad to know!
Dexter
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 6343 views
  • 3 kudos
  • 7 in conversation
Announcements
Orbi WiFi 7
