× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
after move cannot connect to NAS 316
cduggins
Guide
after moving I cannot connect to my NAS, but I am able to still see my son's NAS and connect to it in ReadyCloud
error message from RAIDar........says network error but I can connect to my sons.
I am running Windows 11
Message 1 of 24
Accepted Solutions
cduggins
Guide
Re: after move cannot connect to NAS 316
I did the OS reset and I'm up.
Thanks for your help.
Message 24 of 24
All Replies
Guru
Are you seeing the NAS on the attached device list in your router?
Message 2 of 24
cduggins
Guide
I can see the NAS but it does not accept my login
says not accessible..........need permissions.
Message 3 of 24
Guru
Try running CMD on the PC.  Then enter
net use * /delete /y
net use t: \\nas-ip-address\data /user:admin nas-admin-password
using the real NAS IP address and and admin password of course.  Be careful on the typing - the spaces and the slash directions both matter.
That should mount the data volume of the NAS as drive letter T.  Let us know if that works (or if not, what error you get).
Message 4 of 24
cduggins
Guide
I cannot find a IP for the NAS.........my router only shows the mac address and under IP4 shows unknown
IP6   fe80:eafc:afff:fee6:ed00
Message 5 of 24
cduggins
Guide
I found another list on the router that gives me a IP I am going to try it.
Message 6 of 24
cduggins
Guide
C:\>net user */delete /y net user t: \\nas-ip-192.168.1.110\data/user:admin nas-admin-password
The syntax of this command is:
NET USER
[username [password | *] [options]] [/DOMAIN]
username {password | *} /ADD [options] [/DOMAIN]
username [/DELETE] [/DOMAIN]
username [/TIMES:{times | ALL}]
username [/ACTIVE: {YES | NO}]
I thought I had all the spaces correct...but must be missing something???
Message 7 of 24
Guru
net use t: \\192.168.1.110\data /user:admin nas-admin-password
  1. net use - not net user.
  2. You entered both commands on the same line - they need to be entered separately
  3. You left out the space between * and /delete.
  4. You just enter the IP address, no nas-ip- prefix
  5. You left out the space between \data and /user
  6. Note you enter the actual nas admin password instead of nas-admin-password.
Message 8 of 24
cduggins
Guide
C:\>net use * /delete /y
You have these remote connections:
\\5.225.87.119\Pictures
Continuing will cancel the connections.
The command completed successfully.
C:\>net use t: \\192.168.1.110\data /user:admin nas-admin-password
System error 53 has occurred.
The network path was not found.
Message 9 of 24
Guru
Looks like you still had a connection to readycloud.
Did you type the real NAS admin password at the end of the command?  Or just nas-admin-password?
Message 10 of 24
Sandshark
Sensei
The error suggests that either that's not the NAS at that IP or your main volume is named something other than the default of data.
If you previously set a static IP on the NAS for a different router with a different IP range, it won't show up on your router's list of devices, but should show up in RAIDar.  On a 316, you should also be able to scroll through the display pages and find the IP address.
Message 11 of 24
Guru
@cduggins:Try entering
ping 192.168.1.110
If you get a response that starts with "reply" then try
net view \\192.168.1.110
and see if you get a list of the shares.
Message 12 of 24
cduggins
Guide
my NAS still has the default username and password
Message 13 of 24
Guru
Ok.  I think that might explain the error here:
C:\>net use t: \\192.168.1.110\data /user:admin password
You can only access the data volume this way if the admin password has been changed.
Have you tried other two commands I suggest (ping and net view)?
Also, what happens if you browse to https://192.168.1.110/admin
Message 14 of 24
cduggins
Guide
found I had the wrong IP and had changed the data directory name...here's the results..
C:\>net use t: \\192.168.0.18\CDuggins /user:admin password
C:\>net view \\192.168.0.18
C:\>ping 192.168.0.18
Pinging 192.168.0.18 with 32 bytes of data
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.0.18:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\>
everything else tells me to check my network settings...I think they are correct. I'm sharing.
Message 15 of 24
Guru
Request timed out.
Request timed out.
Request timed out.
Request timed out.
C:\>
What IP address is the PC using?
Message 16 of 24
cduggins
Guide
192.168.1.108 is my PC
Message 17 of 24
Guru
Then you cannot connect to 192.168.0.xxx IP addresses, because they are not on the same subnet as your router (which is using 192.168.1.xxx).
Where did you find the 192.168.0.18 address?  Is this from RAIDar or the NAS LCD screen???
Message 18 of 24
cduggins
Guide
IP was same on both RAIDar and NAS screen
Message 19 of 24
cduggins
Guide
PC setting must be okay because I can get to my son's NAS from my PC and ready cloud and RAIDar and the PC see my NAS.........I don't know why I can't log in.
Message 20 of 24
Guru
The problem is that you set up a static IP address on your RN316 in your old home (and likely then forgot all about it).  That address doesn't work with your current router configuration.  The NAS can't connect to your PC or your router - and therefore can't connect to ReadyCloud either.
The simplest solution is to reconfigure your new router to use 192.168.0.x addresses. If you send me more info what router model you have, I can probably find the setting you need to change.
Another solution is to do an OS reinstall from the NAS boot menu.  If you prefer to do that instead, the procedure is described on pages 81-82 here: https://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
The OS reinstall will
  • reset the NAS network configuration to use DHCP (getting the IP address from your router).
  • reset the admin password back to password.
  • disable volume quota (which can be re-enabled on the volume settings wheel).
Message 21 of 24
cduggins
Guide
home network..this is a AtandT  model BGW210-700
Device IPv4 AddressDHCPv4 NetmaskDHCP ServerDHCPv4 Start AddressDHCPv4 End Address
192.168.1.254  router IP
255.255.255.0   DHCPv4 netmask
On   DCHP sever
192.168.1.64   DHCPv4 start address
192.168.1.253    DHCPv4 end address
Message 22 of 24
Guru
On   DCHP sever
You want to change the three 192.168.1.x addresses to 192.168.0.x (192.168.0.264, 192.168.0.64, 192.168.0.253).
These settings all appear to be on this page of the router web ui:
Message 23 of 24
cduggins
Guide
Message 24 of 24
Top Contributors
Discussion stats
  • 23 replies
  • 3414 views
  • 3 kudos
  • 3 in conversation
Announcements
