- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connect Linksys RE4100W range extender to Netgear R7500 router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just bought a Netgear R7500 router, how do I connect my existing Lindsys RE4100W range extender to it? Thank you.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
There’s nothing to be done at the R7500, except perhaps I you have something set up like the Wireless Access List. Otherwise all the setup actions are at the RE4100W;
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connect Linksys RE4100W range extender to Netgear R7500 router
Hi, Andy,
Thanks for the answer.
hom
- Mark as New
- Bookmark
- Subscribe
- Permalink
One more question, please.
Can now able to connect the Linksys RE4100W range extender to the NETGEAR R7500 router whic is dual band. However the extender can only locate (therefore connect) to the router's 5GHz, but cannot locate its 2.4GHz. Please help explain. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well I’m not really familiar with the RE4100W, but I guess that it will only connect to one band at a time when connecting to the base station. Do you see both bands available from the RE4100W for client computers to connect to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only 5GHz shows up in the extender, 2.4GHz does not exist at all. Thanks..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Btw., both 2.4GHz & 5GHz shown up in the same range extender when I used a Linksys router previously (i.e. before it is replaced by the current NETGEAR router)..
- Mark as New
- Bookmark
- Subscribe
- Permalink
It’s difficult for me to find any information on the RE4100W, I guess you have a manual? You need to check in the manual for any connection configuration options. I don't know enough about the RE4100W to be able to offer useful advice. have you tried the Linksys forums?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your prompt response.
I'll put my question in the Linksys forum to see if anyone can hlep. Cheers.
