Orbi WiFi 7 RBE973
Reply
Missing ip
Nick1990
Follower
Missing ip
Hey so my router says missing ip address was working before no problem for past 1 year I have tryed resting the modem still nothing tryed to plug internet in main supply no good what can I do it's driving me nuts thanks
Message 1 of 2
antinode
Guru
Re: Missing ip
> [...] my router [...]
   What is it?  Look for "Model" on the product label.  Firmware
version?  Connected to what?
> [...] says [...]
   Does it speak those words in a voice which only you can hear, or are
you looking at some kind of message which is displayed someplace when
you do something?
   None of that is a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] tryed to plug internet in main supply [...]
   I don't know what that means.
> [...] no good what can I do it's driving me nuts thanks
   You could try using punctuation and capitalization, if you expect
anyone to read this stuff.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 362 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
