Reply
NightHawk x10 r9000 wifi dropping issue post f/w update
rmsarma
Guide
f/w updated to 1.0.2.32 otw, now i have wifi connection issues keeps dropping every few minutes, any suggestions
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: NightHawk x10 r9000 wifi dropping issue post f/w update
I recommend doing a factory reset, manually loading the FW file, factory reset then set up the router from scratch using IE11 or FF.
Any wifi neighbors near buy? How many and what channels are they using?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 6
All Replies
Guru
Message 2 of 6
Mighty_Putty
Apprentice
Can you verify if your WiFi (and wired if applicable to your environment) connections are dropping as a result of your router rebooting?  Myself and another user are experiencing this issue, and what I've discovered is that disabling Dynamic QoS has restored stability to the R9000.
Message 3 of 6
rmsarma
Guide
I am not sure why the factory reset was needed, but that seemed to have improved the wifi connection issues, there is no change to my wifi surroundings and
my config below
2.4 ghz AUTO(8)
5 ghz (153)
60 ghz (2)
 I did not load the F/w file as the device indicated that it was already updated
Message 4 of 6
rmsarma
Guide
Dynamic QOS is disabled, al devices are wireless except my ooma wired to the router
Message 5 of 6
Guru
Hope it works well. Enjoy.
Message 6 of 6
Discussion stats
  • 5 replies
  • 4225 views
  • 4 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
