Reply
R8000 router acting weird suddenly
BuBBles827
Suddenly the router is blocking my phone from being connected to the WiFi. When I login to routerlogin.net  using my laptop and chrome, I can access the router. But if I make any changes and hit 'apply' all I get is a spinning circle. If I try to log out nothing happens. If I close the browser window then try to login to the router again, I get an alert saying the request timed out and the router can't be accessed. So I reboot the router by unplugging it and then plugging back in. Then I can access routerlogin.net again. But again if I try to make any changes on the router, this cycle happens again.
Also the only way I was able to get my phone on the WiFi was disabling Auto Access on the router. Then my phone wasn't blocked.
Please help. I really don't like leaving access to my WiFi open to any devices connecting unless I ok them. And I don't want to have to reboot the router every time I want to make changes on the router.
Thanks
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 2 of 12
Accepted Solutions
Guru
Re: R8000 router acting weird suddenly
I recommend that you downgrade to v.68 or .62. There are some DNS issues for some users on recent FW. I saw this as well with .76 loaded so I reverted back to v.62. NG is aware of these issues and working on something.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 5 of 12
All Replies
BuBBles827
Re: Nighthawk X6 R8000 Problems
Thanks
Message 1 of 12
Guru
Be sure to clear out all browser caches before going to the routers web page.
Does this happen on other browsers?
Message 3 of 12
BuBBles827
Hi
Thank you for responding.
I was running the previous firmware version when all this started. Then when I logged into the router I saw there was an upgrade so I installed that today. I then double checked that the upgrade actually installed by checking for upgrades on the router.
I've been connected to the Arris TM804 modem for a few years.
I cleared the Chrome caches multiple times.
And this happens on both Chrome and Edge.
Message 4 of 12
Guru
Message 5 of 12
BuBBles827
Hello
I'm not sure how to do that. Can you please post some instructions on how to downgrade.
Also what is FW?
Thanks
Message 6 of 12
Guru
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Message 7 of 12
BuBBles827
Thank You
Message 8 of 12
BuBBles827
Is it imperative to connect laptop to NG router with EtherNet cable.?
That port doesn't exist on my laptop. And the adapter doesn't have that port either.
Message 9 of 12
Guru
So Laptop dosen't have a ethernet port?
It's recommended and preferred.
There are inexpensive USB to ethernet adapters out there.
If you are connected wirelessly to the router and near the router, say 6 feet min, I supposed you can send the FW file down while connected wirelessly...
Message 10 of 12
BuBBles827
Ie: R8000 router acting weird suddenly
Thank You for your help.
I downgraded the router to v68 and now everything works perfectly.
BTW I was able to download the downgrade zip using WiFi and it worked fine.
Thanks again
Message 11 of 12
Guru
Re: Ie: R8000 router acting weird suddenly
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 12 of 12
Discussion stats
  • 11 replies
  • 1135 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
