- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Verison 3G MiFi connectivity
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can a Verizon 2200 3G MiFi be connected to a Netgear Nighthawk AC 1900 - Model R7000 using a USB to Ethernet adapter cable into the ethernet internet input port? I use both Windows XP and Windows 7 operating system based computers.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi NRF,
The R7000 does not support that type of connection. If your 3G MiFi is using a MicroSim card, you might try checking the R7100LG.
https://www.netgear.com/support/product/R7100LG.aspx?cid=wmt_netgear_organic
JamesGL
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi NRF,
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Verison 3G MiFi connectivity
Hi NRF,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I appreciate this reply with helpful advise. As a result I have returned the netgear unit to the store and have decided that my idea to set up a network in hour motor home is simply not going to happen with the Verizon 3G wireless hardware I have. Since I have unlimited data for life with this 3G unit it is highly unlikely I will change my internet service. Too bad. It would have been helpful to have a network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Contact CradelPoint they specialise in mobile Broadband
