Orbi WiFi 7 RBE973
Reply
How to log into your router and not the cable modem, both uses NETGEAR genie
JCH0321
Follower
I have a NETGEAR cable modem (AC1900- C7000). Just bought NETGEAR wireless router NIGHTHAWK X8 (AC5300).
Every time I try to log into the router using the instructions (routerlogin.net) it takes me to the cable modem (AC1900) and not the router where I need to upadate the firmware.
How can I log into the router and modem separate? using routerlogin.net it always takes me to the cable modem???
I'm confused, Appreciate any help
Message 1 of 3
Accepted Solutions
JamesGL
Master
Re: How to log into your router and not the cable modem, both uses NETGEAR genie
Hi JCH0321,
Access it via the IP address of R8500. Check your computer's default gateway and use that address.
Message 2 of 3
All Replies
JamesGL
Master
Hi JCH0321,
Message 2 of 3
JamesGL
Master
Hi JCH0321,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3841 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
