tylernealis86's avatar
Jun 12, 2017
R8000 issues after resetting to factory defaults
I pushed the reset button on the back of the router and now I cannot "configure the internet connection". I can't get into the user interface. Every time I open internet explorer it takes me to routerlogin.net and I cannot complete the process.
I honestly don't think it's a problem with the internet since it was working fine before the reset.
I performed the reset when the internet connection did not return after I restored the factory defaults inside the router interface.
Hope this makes sense to someone?
Thanks in advance for any help
  • All thanks for the input but it started working after the fourth reset.
    The only thing different this time was I disconnected the power to my firestick so that nothing was trying to access the wifi while it was coming online..
    Not sure why the reset worked after I unplugged the firestick but thats all I did??
    Again thanks for the input and the willingness to help me out. I appreciate the forum... much more than netgear since you have to pay to talk to tech support, but whatever....
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem?
    How are you connnected to the NG router? WIred LAN cable PC is recommended.
    Is your connected PC getting an IP address from the router? if so, what is the IP address the PC is getting? Look in status of the network adapter or do a IPCONFIG /all in a command line.
    Be sure your PC is set for automatic obtain IP addressing and not static IP addressing.
    • tylernealis86's avatar
      tylernealis86
      Modem is surfboard SB6183
      I was connected to the router through a patch cable when I was trying to troubleshoot last night.
      Not sure where to look for IP address after I ran the IP config.  I can access the internet if I connect directly to the modem via ethernet cable.
      • FURRYe38's avatar
        You should be good with the SB6183. Same modem I have connected with my R7800.
        IP address of the router should be 192.168.1.1 and accessible from the router side with a LAN cable connected PC or wireless laptop.
        Use IE11, FF or Opera browser to connect to it.
        Be sure your PC is set up for automatic IP address assignement.
  • If you did a reset and reach the login page try admin for the username and password for the password you may have reset the router back default before you set it up via a lan cable and a computer not wifi as the wifi will have the pre programmed username and passphrease they were on a sticker on the router will not be online or in the manual.
    What lights are lighting up and what color?
      tylernealis86
      I cannot reach the login page, I am stuck trying to get through the netgear genie that pops up automatically everytime I try to open the internet browser.
      all lights are white except the internet light which is blinking amber when it is connected to the modem..
      tylernealis86
      I followed the steps in the guide exactly and still same issue persists
  • FURRYe38's avatar
    Any update on this>?
    • William10a's avatar
      William10a
      Master
      I hope that they get the router set up and their internet back.
      • michaelkenward's avatar
        michaelkenward
        tylernealis86 seems to have disappeared. First the question, then the follow up with more information. After that, nothing. Perhaps they fixed it and haven't bothered to tell us.
