- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router Keeps Rebooting
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Netgear doesn't seem to have clue, makes me repeat same troubleshooting steps from script which I have by heart now.
Anyone faced with similar issue ....any resolution?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi Prime40633 and rowe100,
I would suggest contacting support team as it might be a hardware issue.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Router Keeps Rebooting
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
if a router works for days and then just reboots just randomly
sounds like a power issue
MSI X99S GAMING 7
Corsair H110
16GB(4X4GB) GSKILL RIPJAWS4 DDR4 2400
Coolermaster silent pro1000 PS
PowerColor PCS+ R9 290 4GB GDDR5
BenQ XL2720Z
2 Kingston HyperX 3k 240GB ssd Raid0 for OS
corsair 800D
Asus Essence STX II 7.1 | Logitech Z-5500
Windows 8.1 x64 mce
netgear r7000
V1.0.4.4_1.1.37
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
This went on for over a month, I would update then it would randomly reboot. After the many postings I posted describing the issue Netgear contacted me and actually sent a test unit with a serial cable to capture the events. Each time it rebooted I would send them a report and then they would send a beta FW.
My point is FW has caused these types of issues and for some reason not all routers are effected the same way. I had posted asking if others had the same problem and everyone said Not me mine's fine. After several months then others started seeing their router reboot too.
When my 7000 rebooted I saw it reboot, no one else was home and only my laptop checking e-mail at the time. I sit twenty feet from it and caught it when all those idiot lights went out.
It wasn't input power related, not to say that it couldn't be a run of intermittent power warts. I use a true UPS made by Best not this crap sold for under $50. Best converts input ac to dc and then converts back to AC, making it impossible for a drop or spike to get through.
I assume OP tried a different FW version and I would refrain from using USB until the router is proven to be stable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Firmware version is V1.0.3.80_1.1.38 which I upgraded to a couple of weeks ago. I'm not sure if this is when the problem started but it sure is coincidental.
The suggestion above that it could be a power glitch / surge is possible, but I would have thought the router would be fairly tolerant of dirty power as they are designed for home use, where the power is not clean (like a datacenter for example)
Advice above suggests reverting to V1.0.3.24_1.1.20.
I have a support call out with Netgear and if no joy from this I think I will revert to V1.0.3.24_1.1.20.
Would welcome any other advice / comments
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
There seems to be an issue with the USB ports on this router.
Look at the issue people are having with NAS and corrupting hard drives.
Called Netgear somewhere in India I am sure and they told me they do not support file transfers. That is a different issue. I would unplug anything plugged into this router and see if it keeps rebooting on you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Router Keeps Rebooting - Fixed for me
Not sure which one it really is but I suspect more than likely its the reset to default step after installing updates. I saw mentions of that here and elsewhere. The docs and the update process do not mention it but it is buried in a PDF somewhere...not in the version that comes with the router. Its an unnecessary step that must be compensation for a bug, but it worked and is not too hard to handle...though since I autoupdate the firmware, I can assume it will happen again and will need to repeat when reboots resume.
Anyway the 2 steps I took were:
1. Direct connect power to the wall - removed from an older surge protector
2. After firmware updates, backup config. Then restore to factory settings, and restore config from the file. They say this should be done after every firmware...which sucks...and should get fixed.
I have been emailing logs to me every day since then (2 weeks now) and have not had a single unexpected reboot since - things are looking great.
The power thing seems suspect but I have seen other devices including the xbox one mention this as a probable cause of some issues. I suppose it is possible that the devices are more sensitive and/.or the power supply is less clean/consistent power...
But based on the fact that the problems seem to occur soon after an auto update of the firmware it seems the revert to factory settings step is the likely fix.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks
Staudie
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I contacted TS who told me all the normal things to try such as factory resetting etc. I did the 30-30-30 reset with the latest FW, (before and after) but it still happened.
One thing I am trying now is to turn off both up and down QOS which others have mentioned success with - we'll see.
Also disconnected my Magic Jack to see if that's the problem. It's only been 2 hours since I did this with no re-boots so far, so too early to tell but I will report back if things improve.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I am trying to disable ipv6 to see if that changes.....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Interesting... I was looking at my cable modems (SB6141) setting last night and noticed the IP Mode was set to "IPV6 only".
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi everyone - has this been resolved? Any suggestions to avoid the rebooting? My Nighthawk reboots only when accessing certain apps from the Roku 3.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Netgear - is there beta firmware available to address this issue? Huge PITA!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi rowe100,
What is the exact model number of your nighthawk router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have model R8000 AC3200
BTW - Support requested that I go back to an earlier version of the firmware then reset the router using a pin on the button on the back of the router. I went ahead and tried the reset with the current most recent version of the firmware I already had on the router, and right now, it appears to be working!
I will keep testing. I had tried unplugging the power and then powering back up the router, but that didn't work. The reset is working so far, but of course a pain to reset everything. I didn't reload the cfg file as I am guessing it would over write something that the reset fixed.
I will report back how it goes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Good News! So far so good. Resetting the router by using a paperclip to push the reset button the back of the router worked! I have not tried to figure out what setting might have created the original issue, but when I have a free weekend I may try to get to the bottom of it.
User | Count |
13 | |
9 | |
6 | |
6 | |
4 |
