Orbi WiFi 7 RBE973
Reply
amber lights on top of nighthawk 6700
bosoxguy17
I have my amazon fire tv box and PS4 connected to my router via ethernet cable. when i use my ps4 the amber light turns white but when i use my amazon box it stays amber why is this? i feel like the movies i watch through amazon streaming as they shld like on my ps4. what could be going on?
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 11
Accepted Solutions
JamesGL
Master
Re: amber lights on top of nighthawk 6700
Hi bosoxguy17,
The LAN ports of the router is gigabit. If the device connected to it is gigabit as well then the light is white. If the device connected is upto 100Mbps only then the light is amber.
Message 10 of 11
All Replies
@bosoxguy17 wrote:
....the amber light turns white ....
Where is this amber light?
Ethernet port?
The manual (p 11) says:
The LED color indicates the speed:  white for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps Ethernet connections.
Message 2 of 11
bosoxguy17
the top of the router is where the lights are
Message 3 of 11
Guru
Your Amazon FireTV has a fast ethernet connection (100 mbits), and your PS4 has a gigabit connection (1000 mbits).
The router shows fast ethernet with amber, and gigabit with white.  So there is nothing wrong with the router (or the two devices).
Message 4 of 11
I know where the lights are. I really wanted to know which of the dozen or so lights changes colour.
StephenB has given you the same answer that I gave.
Does that answer your question?
Or is it a different light that changes colour? Not the LAN indicator.
The manual is here:
R6700 | Product | Support | NETGEAR
Page 11 refers to the LAN lights.
Message 5 of 11
bosoxguy17
sorry it was the corresponding lights to the devices n the spends of the devices would explain that i just could have swore the amazon light was once white thank you both for your help
Message 6 of 11
bosoxguy17
speeds*
Message 7 of 11
amazon light?
Message 8 of 11
bosoxguy17
yeah on the router it's connected via ethernet so ita light 1 on the router is what i meant
Message 9 of 11
JamesGL
Master
Hi bosoxguy17,
Message 10 of 11
JamesGL
Master
Hi bosoxguy17,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 5017 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
