- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
"routerlogin.net" keeps saying I must be connected to my router's WiFi, even though I am
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was having connectivity issues with my Verizon Fios router. They sent out a technician and the problem was fixed. After my netgear wifi router was reset, I attempted to go to "www.routerlogin.com" to change my name and password back, only to get the messge, "You are not connected to your Router’s WiFi network. To access routerlogin.net, your device must be connected to your Router’s WiFi network. Check your current connection and try again."
I clicked on more information and none of their suggestions worked for me. I've also perused through the community solutions and nothing worked for me. I tried the Genie app and it wouldn't allow me to login (it would just keep loading).
I found my router address and made it to the Verizon page, changed the name there but couldn't change the password. I don't want the Verizon wifi. I bought this expensive netgear equipment for a reason. I don't have any anti-virus programs (like Kaspersky) on my computer. I have a Mac. I've also tried to log in on different computers (Mac, Macbook, iPhone...) and browsers (Safari, Firefox, and Google Chrome). I've reset the router, restarted the computer, updated the computer, diasabled firewall and popups. Nada.
I'm not very well versed on technoloigcal terms so if you can please help me in lay man's terms!
Computer: Mac
IP Address: 173.70.96.177
Router: 192.168.1.1
Provider: Verizon Fios
Netgear: R8500 NightHawk
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
So to anyone with the same issues as mine, check your cables and make sure there aren't extras. All that's needed is the Ethernet cable connecting the FIOS router to the NetGear and the plug in from the NetGear to the outlet. Make sure you reset when removing a stray, unnecessary cable. It worked for me.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: "routerlogin.net" keeps saying I must be connected to my router's WiFi, even though I
Have you tried a lan cable between your computer and router to log in?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
my observation is that routers associate with one web UI address or the other..if your router works with routerlogin.com, it won't work with routerlogin.net
i have a R8000 (X6) with 10.0.0.1 IP and it works with routerlogin.net. My R9000 (X10) on the other hand has 198.162.1.1 works with routerlogin.com. if i try to login to the router UI on routerlogin.net while connected to the X10, i get the same error message
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Adewale wrote:i have a R8000 (X6) with 10.0.0.1 IP and it works with routerlogin.net.
Netgear says that sometimes a router will adopt that address if it sees a conflict with the modem.Or, in the manual's words:
The default IP address for the router is http://192.168.1.1. If the modem router detects a conflict with a WAN IP address, it changes its IP address to 10.0.0.1 or 172.16.5.1.
That's why you have to start a network in the right order.
Sequence to Restart Your Network
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
The easiest way to find the correct IP address is to use ipconfig in Windows.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
quote{I tried the Genie app and it wouldn't allow me to login (it would just keep loading.)}
Have you tried removing or disable Genie and then try to log into the router ?
Running a antivuris program?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is Genie that is the problem are you running windows 10?
Genie does not always get along with other programs it is not Genies fault it is not alone other non Netgear programs have issues with windows and other programs that protect your computer it is not a new problem with computer programs.
Any updates of any type when the issue came up?
Any changes to your set up?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@William10a wrote:It is Genie that is the problem are you running windows 10?
The new desktop Netgear Genie (Version 2.4.36) works fine here in Windows 10.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@AngelaV wrote:only to get the messge, "You are not connected to your Router’s WiFi network. To access routerlogin.net, your device must be connected to your Router’s WiFi network. Check your current connection and try again."
This might be interesting:
Solved: Re: "routerlogin.net" keeps saying I must be conne... - NETGEAR Communities
As I read it, JamesGL, a moderator, is saying the the error message is wrong. Nothing to do with wifi.
This may also be useful:
Solved: Router not connecting to network - NETGEAR Communities
It says there:
I realized today that I had hardwired it to the computer but also was accessing it via wireless. There was a conflict. As soon as I disconnected the hard wire everything fell into place.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did not mean that windows it's self but other programs that be running in the back round on windows Netgear is no the only software that had problems Furuno had a demo for a computer the show it products and if you had any type of vuris protection on it the program would shows errors that were not there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have an iThing?
There may be a genie for that. Some people use that to manage routers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As for the wiring, I'm connecting wirelessly. I even tried to disconnect my Verizon router from my Netgear but that still didn't fix the issue (so I reconnected).
And let me just say, I was so desperate to get this fixed that I called the NetGear customer "service". They asked me for information only to tell me that they wanted to charge me in order to help me. I already paid a bunch for this router (that works fine, I just can't change the name) and I wasn't going to pay more.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
your verizon FiOS is a modem/router so i belive you're not connected to your router but you are accessing the internet through the FiOS. a second possibility is that your Netgear router has been configured as an access point
Solution:
1. disable the router function of the FiOS so you can isolate your Netgear router signals (assumption is that your router is not working as an AP).
2. if you have to, do a hard reset on your router, switch off the wifi adapter on your macbook and connect to the netgear router via an ethernet cable. and try to login to the router UI again
- Mark as New
- Bookmark
- Subscribe
- Permalink
@michaelkenward wrote:Do you have an iThing?
Did you mean a Samsung iThing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm connected to the Netgear network and I can access the Internet just fine. Our FIOS had crapped out and we hadn't been able to connect to the Internet. Now that the router has been replaced, the Internet works again.
I have no idea how to disable FIOS router function either. And we'd prefer not to mess too much with the FIOS because they just sent us a new router and fixed it, and if it craps out again we get charged by Verizon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you call your ISP (Verizon), they should be able to configure your modem as a bridge instead of being a router remotely at no charge to you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bright house modems also have a router made in to them you can access at a limit level to get some control but if you use both the modem and router functions you paids rental fees on both.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the modem/router is in bridge mode the router including it's wifi will be disable and the Netgear router can function normally.
Get the make and model of your modem and down the manual for it or you may have to your isp set the modem to bridge for you depending on the degree of control they have over the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@AngelaV wrote:
But would doing that help the situation with the NetGear router login?
Excellent question. The answer you got is not clear to me. It looks like a major detour from the issue in hand. I fear that we are getting lost in a fog of confusion.
Let's get back to basics. Things seem to be working, so do you really need to change anything?
Oh, and your first message referred to a "Verizon Fios router". I assume that this is a modem/router.
Did you follow this:
when you restarted the network? The order is important when you have a modem and a router talking to each other.
