- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120 V2 Constant Random Reboots
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120 V2 Constant Random Reboots
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What's the first 3 characters of the routers serial number that you have please?
@davidrbill wrote:
I have been battling this since purchasing as well. Netgear requested I update to the .40 firmware and do a factory reset afterwards, but it did not resolve the issue. They also requested I change the DNS server addresses to static with relevant addresses, and it also did not resolve the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've owned this router for 8 months now and have always had the random reboot issue through all the firmware versions. I sent a private message to DarrenM to request the beta/release candidate firmware and he graciously sent it to me last week for me to test and provide feedback.
Since applying the new firmware, I have nearly 5 days of continuous uptime without a single reboot. Before the update I was getting random reboots within 24 hours and never made it to 48 hours of continuous uptime. My router is located in a closet that stays warm (~90F ambient) and this heat is having zero impact on the router performance with no cooling accessories required. Everything is stock original including the power adapter and I'm even maximizing the throughput using a 5Gbps uplink.
I think the Netgear engineering team has really solved the issue with this firmware and hopefully they will be able to give it a GA release very soon if others are reporting the same successes without issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it's working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
I recommend placing a USB Laptop cooler is recommended under the router. Keeps the router cooler and helps avoid heat damage over time.
Enjoy. 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
Keep it up guys and I may just be able to stay on the NG Team.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the first 3 characters of the routers serial number please.
Did you factory reset the router and setup from scratch with out using any saved config backups from file?
Also change the default DHCP IP address pool range to .100 to .200.
Others have seen long past 3 days with out reboots. So you maybe seeing something else that's causing problems...Need to narrow it down more.
What devices do you have all connected?
How is Basic and Advanced Wireless settings configured?
@GMCbroMAN wrote:
Same issues, roughly same amount of time owned. And now I too have updated with Beta Firmware and 1st reboot was about 3 days after update, it was around 12pm which if that's the case doesn't truly affect me and I can definitely rest a little easier if it keeps it up. This seems to be the closest thing to a fix yet
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update: I have only had one unexpected reboot since installing the beta. The problem might be related to an Ethernet port on one of my PCs. I swapped out the RAX120 with my old router and could not reproduce the problem there, so something is still going on with the RAX120 but other than that it has been stable on the beta. Now on 12+ days after an initial 11+ days (so just one reboot over the past 23 days). Hoping the general release comes out soon to fix the other issues with the stats page not loading.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What's the ethernet brand and model#? Be sure drivers are up to date for that adapter. Might try swapping in a different adapter if you feel this could be an issue here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120v2 keeps randomly restarting
I tried using a laptop cooling pad with a fan. It didn't stop the problem but it seems it speeds up the rebooting process so that the wifi is not down as long. But I still have my router rebooting several times a day.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the first 3 characters of your routers serial numbers please.
Did you get ahold of the beta FW file for this yet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It appears to be a hardware issue. Wiggling the connector in the jack causes the pins to short or open, which interrupts network traffic. Drivers are up to date.
The adapter is soldered to the motherboard, so no chance to change it out. It is a pint sized PC.
My point is that my old router doesn't seem to care, but the new one is more sensitive. I will find a way to resolve the PC issue separately. Otherwise the router has been fine on the beta.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Maybe the RAX is more sensitive.
So no adding of any kind of PCI card?
Does this PC have a USB 3.0 port by chance? If so, I would get you a USB to ethernet adapter, then you can stop using that onboard LAN port. I would avoid using it if it's shorting like that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello David
I have sent you a Pm.
Thanks
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Needed to upgrade my router up at my cabin, so I bought this and boy has it been a mess. It's fast and puts out a strong 5Ghz signal but it gets overwhelmed all the time and the internet just starts chugging, dropping down to horrid speeds until it finally just lags out or reboots.
It's dropping all connections too, wired and wireless. I have a two APs in my house that are wired in and I use those for my 2.4Ghz smart home stuff, on separate SSIDs.
I turned off WMM and that helped a bit but still losing connection/rebooting 2 times a day. I finally just turned off the 2.4GHz all together but it didn't help.
Could you please point me in the direction of the beta firmware. I was mainly running Voxel's builds on my R7800 and now that all that's available for this is stock firmware I'm cringing at my purchase.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the first 3 characters of your RAX120 serial number?
@Obsidian_ wrote:
I need to get my hands on that firmware because mine is doing the exact same thing. I previously had the R7800 and it was perfect. It could easily handle all 60 of my connected devices without issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Please, can I test this beta fw?, I just bought a rax120v2 and also have this random reboot issue, I opened a case on 2022-11-16 and they never mentioned anything about a beta fw, or be of any help what so ever.
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi
can anyone send me the beta pls
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can i get the firmware? same problem in late 2022
