Orbi WiFi 7 RBE973
Reply
Smart Parental Controls Failing to activate
In the orbi app, when I click on smart parental controls > activate now > The app goes through about 10 seconds of "setting up..." until I get an error. The message says "Smart Parental Control activation is failed.Please try it again, or dismiss this message and try it later (code: SPC-ACT-FAIL)."
Please Help!
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 7
Accepted Solutions
ChristineT
Admin
Re: Smart Parental Controls Failing to activate
Hello @cashchris2005 ,
Thank you for sharing your experience with the NETGEAR Smart Parental Controls (SPC) service. We have received a handful of reports similar to yours and have been able to implement a patch for this issue. Will you please try to activate the SPC service again and let us know if the issue persists?
Steps to enable Smart Parental Controls (SPC):
  1. Log into the Orbi or Nighthawk app depending on which model router you have
  2. Locate and tap on the Parental Controls tile
  3. Swipe option to Enable Smart Parental Controls
Please let us know if the issue persists.
Kind Regards,
Christine
Message 7 of 7
All Replies
Probably should have mentioned I have reset my orbi system already as a troubleshooting step.
Message 2 of 7
It might also be worth trying this one over here:
NETGEAR Smart Home Parental Controls - NETGEAR Communities
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 7
Fixmyorbi
Initiate
Has there been a response by Netgear to this problem?  Thanks
Message 4 of 7
No response yet. I’ve messaged both here and in the app to netgear and silence.
Message 5 of 7
CrimpOn
Guru
This may be because Netgear support staff do not participate in the community (customer) forums.
As I have absolutely no idea what could be causing this problem, can you please humor me with this question:
Does the Orbi web interface have a menu item for Parental Controls?  (mine does).  What happens if you select "Upgrade to Netgear SPC" on the web interface?
I love my Orbi.
Message 6 of 7
ChristineT
Admin
Kind Regards,
Christine
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2451 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
