Orbi WiFi 7 RBE973
ERR_SSL_KEY_USAGE_INCOMPATIBLE
100won
Star
Google wrote: "
  • Require X.509 key usage extension for RSA certificates chaining to local roots
    X.509 certificates used for HTTPS should contain a key usage extension that declares how the key in a certificate may be used. Such instructions ensure certificates are not used in an unintended context, which protects against a class of cross-protocol attacks on HTTPS and other protocols. For this to work, HTTPS clients must check that server certificates match the connection's TLS parameters, specifically that the key usage flag for “digitalSignature” and possibly “keyEncipherment” (depending on TLS ciphers in use) are asserted when using RSA.
    Chrome 117 will begin enforcing that the key usage extension is set properly on RSA certificates chaining to local roots. Key usage is already required for ECDSA certificates, and for publicly trusted certificates. Enterprises can test and temporarily disable key usage enforcement using the RSAKeyUsageForLocalAnchorsEnabled policy (available in Chrome 116). "
We can not access orbilogin.com local site anymore. While waiting for Netgear developers fix this problem, we will do step by step:
1. Copy these below and save as: "name.reg"
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Edge]
"RSAKeyUsageForLocalAnchorsEnabled"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Google]
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Google\Chrome]
2. Run "name.reg" file and restart windows.
Cheers,
Message 1 of 14
Accepted Solutions
schumaku
Guru
Re: ERR_SSL_KEY_USAGE_INCOMPATIBLE
SXR80/SXS80: here
SRR30/SXS30: here
Message 7 of 14
All Replies
Mewohkie
Tutor
So navigating to HKEY_LOCAL_MACHINE\SOFTWARE\Policies in regedit on my Windows11 23h2 machine and there is no \Google folder/path no chrome folder/path and under Microsoft, no Edge folder/path.
Manually adding them and then adding the registry values to them does not fix this either.
Message 2 of 14
100won
Star
Hi,
I tested in my laptop before posting here.
I usually use edge and chrome browser.
Message 3 of 14
ReneD
NETGEAR Moderator
Hello @100won,
And welcome to the NETGEAR Community! 🙂
This is already an ongoing issue and there is a patch firmware that fixes this. The official firmware is on its way but we do not have ETA on it. Please download the beta firmware on the link provided below and load it to your router and satellite. You can use a firefox browser to login to your GUI and load the firmware provided. After loading the firmware, a full factory default is necessary on the router, then you test if you can use Chrome or Edge after.
SXR80
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/8b0000016X7a/hXgDguHy6KPFdIw0Pk7j20pSnT8m1DbDmxB...
SXS80
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/8b0000016X7f/.SnEz0b73uDzUNo65ym0zhG6TcQvCFQ8AW5...
Take note to update the satellite firmware first before the router. You may want to check the link below related to your issue.
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/Chrome-Certificate/m-p/2367330#M68...
Have a lovely day,
Rene D
Netgear Team
Message 4 of 14
MELGEAR
Trying to enter the menu of the Orbi-Pro-router using Edge or Chrome can lead to the message:
It looks like the webpage at https://.... ight be having issues, or it may have moved permanently to a new web address.
If it is only about being able to enter the Orbi-menu of the Orbi-router, please use an alternative browser as a quick fix, for example: Firefox.  That worked for me very well to ignore the error message and to enter the Orbi menu/interface.
Message 5 of 14
Rillekille
Guide
Hi @ReneD !
If there is a patch firmware for this issue I'm also in need for it.
Can you please refer me too?
Best regards
/Rickard Hökros
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 6 of 14
schumaku
Guru
SXR80/SXS80: here
SRR30/SXS30: here
Message 7 of 14
MartijnS
Guide
Is there also a patch for the SRS60?
Message 8 of 14
Chris_888
Initiate
I second that, even if it's a end-of-life product, not being able to access the login page to configure the router settings make my router obsolete and un-usable. Orbi app lack to many advance setting that i require.
@ReneD Please bring patch to SRR60 router and SRS60 satellite users. 🙂
Thanks
Message 9 of 14
schumaku
Guru
@DavidGo can you jump in here again please? If wally brain is right, you mentioned there is a build with a possible fox for the SRR60/SRS60/SRK60.
Message 10 of 14
DavidGo
NETGEAR Expert
Message 11 of 14
Rillekille
Guide
@ReneD Any patch for the RBK50?
Regards
/Rickard
Message 12 of 14
Chris_888
Initiate
Hi @schumaku and @DavidGo
I updated SRR60 and SRS60 ( with firefox, I didn't know it worked using that browser ) and I can now access my router login with Chrome/Edge again!
Many thanks
Message 13 of 14
schumaku
Guru
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 19323 views
  • 9 kudos
  • 9 in conversation
Announcements
