Orbi WiFi 7 RBE973
Reply
Outdoor Options for Extending Orbi Pro WiFi 6 Network
wesmithjr100
Guide
I currently have an AX6000 Orbi Pro setup (1 router + 2 satellites).  I'd like to extend range outdoors for better connectivity for outdoor cameras, etc.  I did a search of the forums and the RBS50Yv2 looks to be compatible with the Orbi Pro WiFi 6 line but wanted to confirm as much along with also confirming whether it should be setup in Extender or Orbi mode since I saw at last one reference to setting up in Extender.
Thanks,
Bill
Message 1 of 7
Accepted Solutions
Guru
Re: Outdoor Options for Extending Orbi Pro WiFi 6 Network
there are outdoor AX access points but they'd need to be hardwired.
For example.Cloud Managed WiFi 6 PoE Access Point | NETGEAR
Message 4 of 7
All Replies
Guru
As far as I'm aware it only runs in extender mode with the new AX mesh.
Its not compatible in Orbi mode.
Message 2 of 7
wesmithjr100
Guide
Thanks. Would be nice to have an option that is Wifi 6 and more directly compatible with the AX mesh systems but I guess in the absence of that, this is likely the best option
Message 3 of 7
Guru
Message 4 of 7
wesmithjr100
Guide
Definitely prefer as "wire free" a solution as I can find since access to a PoE switch among things could be a challenge.
Message 5 of 7
Guru
Most will run off a POE injector and don't necessarily need a switch.
The WBC502 has an access point mode (netgear airbridge) and can run off a POE injector as well.
Message 6 of 7
wesmithjr100
Guide
Thanks for the info.  Until recently, I haven't really looked into outdoor options but with some of the added outdoor cameras / IoT type stuff I'm looking to add, really need the added range an outdoor AP, etc would provide.  I'll definitely take a closer look at these options
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3568 views
  • 1 kudo
  • 2 in conversation
Announcements
