Orbi WiFi 7 RBE973
Reply
SXK80 stuck flashing white
bluejeans
Hi all - my router is stuck flashing white, despite reboots and reset attempts (holding reset button down for >7 seconds.
Any suggestions would be much appreciated!
Ben
Message 1 of 5
Guru
Re: SXK80 stuck flashing white
Can you not access the routers web page at 192.168.1.1 after pressing the reset button for 15 seconds then release with a wired PC and web browser?
Message 2 of 5
bluejeans
Sadly, no.  I have the pc set to fixed ip 192.168.1.100 on the ethernet adapater, have the network cable pluugged into one of the LAN ports on the router (not the WAN port.)  I just tried powering on, giving it a moment and then doing the 15 seconds you suggested.  Was not able to see 192.168.1.1 in the web browser.
I also have tried the steps recommended to manually update the firmware with the same hardwired setup but was unable to get a connection to 192.168.1.1 even if the router had been powered on for like 10 minutes (with the white LED still blinking.)
Message 3 of 5
BruceGuo
NETGEAR Expert
What did you do before you saw AP is stuck?
To recover it, please follow this link
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Message 4 of 5
Guru
did you get it working with a tftp client?
You can try recoving it with either tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done with tftp.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
I haven't used nmrpflash on the pro line but I've used it a couple times on the consumer equipment with good results.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1012 views
  • 1 kudo
  • 4 in conversation
Announcements
