- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Blocking Websites - Solved
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Blocking Websites - Solved
Can't even log into the website AND the certificat for a Netgear website has expired. That doesn't make me very confident in a company that is supposed be branded by "security".
- Mark as New
- Bookmark
- Subscribe
- Permalink
What browser are you using? Happens in IE11, FF or Opera?
@notjoeone wrote:Can't even log into the website AND the certificat for a Netgear website has expired. That doesn't make me very confident in a company that is supposed be branded by "security".
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The RBRs web page?
What NG Orbi do you have?
@Spgleason17 wrote:
Unable to access website to change settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know.
Enjoy.
@jflorez wrote:
Thank you. I had the same issue after switching from Comcast to fiber optic. I could not access some websites and certain apps such as Netflix (I could access it but I couldn’t stream). When i logged into the fiber optic’s wifi i was able to access those pages. But when i logged into Orbi, I couldn’t. After digging around I found this post and it solved it. Just add the https protocol so Orbi does not block it when the website does not specifically specify it in its URL. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
ARGH!
Brand new to Orbi and it's working great for all of the phones in the house - not so for my laptop/iPad. Same "connection not secure" situation. So I took someone's advice about traceroute on my Mac and found this:
traceroute to 8.8.8.8 (8.8.8.8), 64 hops max, 52 byte packets
1 10.0.0.1 (10.0.0.1) 4.757 ms 7.031 ms 4.356 ms
2 192.168.1.1 (192.168.1.1) 4.367 ms 5.982 ms 6.424 ms
What now? It's been a long time since I was semi-computer literate. As someone else said, I bought an Orbi because it was "simple and easy to use"!
This RBK50 said it was updated to the latest firmware on install (3 days ago).
I have no problem using the phone app and I really wish there was a way to fix this issue there.
I'm using the "performance two-pack". The route & the satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After a fruitless 50minute phone call with NetGear (40min hold time), I was simply told to call Verizon.
I think my Verizon G1100 router is competing with my Orbi RBK50v2.
Is there any way to designate proper roles to each and move on?
This seems like such a rampant issue but I've yet to find a clear solution via multiple forum readings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Another point of inquiry:
Can't I simply remove my Verizon G1100 router and just go straight into my Verizon BIGBOX that's wired up to the brick walls of my basement?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you so much for this solution! I wired into each satellite as well as the router and confirmed internet was working. My PC and phone were connecting just fine, but my Fire Sticks and Samsung TV's were failing to connect until I found your post. As soon as I saved the setting my TV connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@MossyBoots wrote:Another point of inquiry:
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://support.meetcircle.com/
Is there a permanent fix?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do you perform this when Orbi is blocking access to the the login site? I switched networks, but then of course, I can't login into the router when I am not on the Orbi network. This issue is infuriating!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
You need to be on the same network as Orbi.
Do you have two routers?
@azdbo608 wrote:How do you perform this when Orbi is blocking access to the the login site? I switched networks, but then of course, I can't login into the router when I am not on the Orbi network. This issue is infuriating!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't even go to the Orbi login website without it blocking it for me. What am I doing wrong?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What do you mean by blocking it? You can't access the RBRs web page?
Do you have Armor or Circle enabled?
Try using a different web browser.
@JacksonM wrote:I can't even go to the Orbi login website without it blocking it for me. What am I doing wrong?
- Mark as New
- Bookmark
- Subscribe
- Permalink
block website on specific devices connected to orbi mesh network
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: block website on specific devices connected to orbi mesh network
@bdiges wrote:
I want to block youtube on the devices my kid uses. but not on the device I use. can we do that with orbi mesh network?
Not with the default Orbi on-board keyword blocker - which can work with clear text http only anyway - I'm afraid.
The only way to achieve this is using some App on the end-point, like the Smart Parental Controls which comes in two flavors (Circle or Netgear Smart Parental Controls SPC) depending on your product. More and more devices will be added or migrated from Circle to SPC with coming-up firmware updates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Netgear!
I have the RBR850, newest mesh system with 2 satellites. I love it! However, there are a few issues with blocking that I'd like to eliminate. We're experiencing a temporary 'unavailable' status on some websites, and it takes 2 tries to get them to open up. When they finally connect it doesn't specify the connection type.
I followed the instructions to add the HTTPS and that helped. There is a WHOLE list of possible 'Service Types' that could be added as well. Are there any others that I could safely add to improve my connectivity? I hope someone knows which of the types below are safe to add:
ANY (UDP)
AIM
AGE OF EMPIRE
BGP
BOOTP CLIENT
BOOTP SERVER
CU-SEEME (7648)
CU-SEEME (24032)
DNS
FINGER
FTP
HTTP
HTTPS (already added)
ICUII
IDENT
IP-PHONE
IRC
NET MEETING
NFS
NEWS
QUAKELL
RCMD
REAL-AUDIO
REXEC
R LOGIN
R TELNET
RTSP
SFTP
SMTP
SNMP
SNMP TRAPS
SQL NET
SSH
STRMWORKS
TACACS
TELNET
TFP
VDOLIV
VPN-IP
VPN-IPSEC
VPN-L2TP
PPTP
Thank you!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@LinderB wrote:However, there are a few issues with blocking that I'd like to eliminate. We're experiencing a temporary 'unavailable' status on some websites, and it takes 2 tries to get them to open up. When they finally connect it doesn't specify the connection type.
The new modern trend by the Web browser makers ot hide things - click into the broser URL line eg. behind the text and the protocol (typically https:// or rarely the http:// ) will show up.
@LinderB wrote:I followed the instructions to add the HTTPS and that helped.
Very unlikley. If you block https (this is port 443/tcp) and http (port 80/tcp) virtually no usual web site would be reachable....
- Mark as New
- Bookmark
- Subscribe
- Permalink
@LinderB wrote:Hello Netgear!
ANY (UDP)
AIM
AGE OF EMPIRE
BGP
BOOTP CLIENT
BOOTP SERVER
CU-SEEME (7648)
CU-SEEME (24032)
DNS
FINGER
FTP
HTTP
ICUII
IDENT
IP-PHONE
IRC
NET MEETING
NFS
NEWS
QUAKELL
RCMD
REAL-AUDIO
REXEC
R LOGIN
R TELNET
RTSP
SFTP
SMTP
SNMP
SNMP TRAPS
SQL NET
SSH
STRMWORKS
TACACS
TELNET
TFP
VDOLIV
VPN-IP
VPN-IPSEC
VPN-L2TP
PPTP
Thank you!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I followed the procedure but the default port number for all websites was 443. That doesn't seem right. Plus, is this method bypassing security protocol and just allowing all websites through, regardless of their certificates, expired or not?
@jeffbr26 wrote:ORBI is blocking HTTPS websites that are not explicitly defined in URL.
To unblock any https website, do the following:
Log into to your router admin console (https://orbilogin.net)
Click on Advanced Tab
Click on Security >> Block Services
Click Add
Click on Service Type DropDown and Select HTTPS
Click Add to save
Your all set. Close out admin and then retry ORBI admin console as just orbilogin.net and waalaa.
