- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS108Tv2 cannot disable port mirroring
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently enabled port mirroring on this switch (after messing a lot with confusing error messages). Now I'd like to disable again, but I can't. I was able to set "Session Mode" to "Disable" again, but I'm not able to completely remove mirroring config. Trying to do so will result in "Error! Unknown Interface":
Any idea how to fix this apart from doing a factory reset?
Software version is 5.4.2.22 (upgrade to 5.4.2.36 won't work either)
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@lsng wrote:
Now I'd like to disable again, but I can't. I was able to set "Session Mode" to "Disable" again, ...
There is no more disable than disabling the port mirroring session. It's disabled at that point, perfectly fine.
No way to "remove" the pre-set mirroring config(s).
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS108Tv2 cannot disable port mirroring
Well then, if you say so 😀
Thanks!
User | Count |
6 | |
2 | |
1 | |
1 | |
1 |
