Orbi WiFi 7 RBE973
Reply
Management VLAN GS908E
jjamknight
Does this device allow me to move the management VLAN from 1 to XX.
At the mo, i cannot remove VLAN 1.... from all ports.... Using Port 1 as a trunk Untagged VLAN 40 DHCP unable to obtain the device IP from VLAN40
thanks
Model: GS908E|8-port Gigabit Ethernet Smart Managed Plus Switch with Cable Management
Message 1 of 3
Accepted Solutions
schumaku
Guru
Re: Management VLAN GS908E
There is no management VLAN on most Smart Managed Plus switches (GSxxxE). The tiny management microcontroller for the switch config does work and listen on all VLANs so restricting to just one VLAN isn't possible unfortunately.
Port 1, VLAN 40 [U]tagged does also require PVID 40 so untagged frames to the switch will be assigned to the VLAN 40. And don't forget to remove the Untagged assignment for VLAN 1. This won't help for the use case where you have multiple VLANs with DHCP servers, the switch can pick-up DHCP IP from any VLAN for the reason explained above. The only option is using a static IP config for the IP subnet in use on that VLAN 40.
Message 2 of 3
All Replies
schumaku
Guru
Message 2 of 3
jjamknight
Thank you for the speedy reply... i agreed in fact making the IP static on that VLAN works for me.
Cheers
Message 3 of 3
Discussion stats
  • 2 replies
  • 1491 views
  • 1 kudo
  • 2 in conversation
Announcements
