Orbi WiFi 7 RBE973
Reply
What version of GS724T does not require JAVA?
E71
Hi all,
Does anyone know if GS724Tv2 requires Java Runtime for its web interface?
I need a GS724T that works without Java but it seems that version 3 (GS724Tv3) onward DOES require it.
Unforunately, the online manual for GS724Tv2 appears to be a little too generic and points to the same one as GS724Tv1 as well as several other FSxxxT range switches so I can't trust that information...
Thanks,
E.
Model: GS724T|24-port Gigabit Smart Switch
Message 1 of 6
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: What version of GS724T does not require JAVA?
Hi E71,
I believe that Java runtime is not required in accessing the web-GUI of the GS724Tv2.
DaneA
NETGEAR Community Team
Message 2 of 6
All Replies
DaneA
Hi E71,
DaneA
Message 2 of 6
E71
Thanks.
Message 3 of 6
DaneA
Hi E71,
You're welcome! 🙂
Feel free to post your future concerns here in the community.
DaneA
Message 4 of 6
hokie21
Tutor
I have the v3 and I would not say that Java is required. There is one page that doesn't work without Java, but the functions on this page can also be accessed using other non-Java tabs. Blinking lights using Java are nice, but not required.
Message 5 of 6
Napsterbater
Apprentice
I have a v4/400nas. Like poster above, one page, which I think is suposed to dispaly a visual of the switch" dosnt work, but its not needed, all settings and funtions are asseiclbe with out it.
Message 6 of 6
Discussion stats
  • 5 replies
  • 6141 views
  • 3 kudos
  • 4 in conversation
Announcements
