× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
ReadyNASOS 6.9.4-RC2
OOM-9
NETGEAR Expert
Latest beta: ReadyNASOS 6.9.4-RC2
• ARM (102 / 104 / 2120 / 202 / 204 / 212 / 214)
• x86_64 (312 / 314 / 316 / 422 / 424 / 516 / 524 / 526 / 528 / 626 / 628 / 716 / 3130 / 3220 / 3312 /...
To install: Click on appropriate link above for your system to download firmware image.
Then upload that image from the management UI's System->Settings->Update->Install Firmware section.
Changelog
  1. [Beta 1] Fixed admin UI offline in cases where the ReadyNAS is not online and perform an update via offline method
  2. [Beta 1] Fixed RR33xx and RR43xx warm reboot after unit has been on for more than a month*
  3. [Beta 1] Fixed not able to see ReadyNAS on LAN with ReadyCLOUD**
  4. [Beta 1] Fixed Apps utility (rn_nml) issue in user set NML**
  5. [Beta 1] Fixed cases with ReadyCLOUD iOS client would report error 409 **
  6. [Beta 1] Fixed OneDrive to better handle files with unsupported characters.
  7. [Beta 1] Fixed AV to allow scanning OS filesystem
  8. [Beta 1] Updated the kernel
  9. [Beta 1] Security samba update
  10. [Beta 2] Updated configuration to provide better drive stability. (RN528 / RN628 / RR2312 )
  11. [Beta 2] Fix for shutdown and reboot issues in limited cases.  (RN204 / RN214)
  12. [Beta 3] Updated security settings with our CSRF Protection **
  13. [Beta 3] Fixed some cases where ReadyCLOUD was preventing upload or download on the local network **
  14. [Beta 3] Fixed ReadyCLOUD VPN connectivity issues **
  15. [Beta 3] Added time and Date format configuration available under the Overview page (Device Time)
  16. [Beta 3] Updated time and date through out the UI to be more consistent
  17. [Beta 3] Added a simplified Alerts with the email logins for Google and Microsoft Accounts
  18. [Beta 3] Added option to filter email alerts based on the severity
  19. [Beta 3] Added app feedback in cases of depends/conflicts/breaks
  20. [Beta 3] Added apps now provide an EOL option for cases of purchased apps that are still available
  21. [Beta 3] Added WOL support in the backup settings to send a WOL packet before a backup starts (Backup Jobs and ReadyDR)
  22. [Beta 3] Added cloud download sync interval for more bandwidth conscious services or ISPs
  23. [Beta 3] Added cloud service Amazon S3 custom URL settings
  24. [Beta 3] Added hot fix logging and displayed under Overview
  25. [Beta 3] Added more information for volumes in read-only
  26. [Beta 3] Added the configuration backup to allow users to restore volume schedule configuration
  27. [Beta 3] Optimized some settings with BTRFS quotas
  28. [Beta 3] Added an option to configure AV to scan the OS (except 100 series)
  29. [Beta 3] Added iSCSI iSNS setting
  30. [Beta 3] Added iSCSI Network binding
  31. [Beta 3] Added Network search domain or DNS suffix setting
  32. [Beta 3] Added an admin profile option for log out, current admin user's password change and other resources
  33. [Beta 3] Updated the admin search to help make file, KB and community searching more accessible
  34. [Beta 4] Updated Email Alerts (Google and Microsoft) UI
  35. [Beta 4] Updated Cloud Service Download Sync Interval options to have Seconds, Minutes, Hours and Days
  36. [Beta 4] Updated the File Backup title and added tooltip
  37. [Beta 4] Added ReadyDR to support the RN2xx Series
  38. [Beta 4] Added Apache cache configuration change to allow for UI hotfixes
  39. [Beta 4] Fixed UI issue with Check for Updates for production firmware
  40. [Beta 4] Fixed some UI 24-hour time issues
  41. [Beta 4] Fixed iSNS configuration issues with reverting configuration
  42. [RC2] Fixed a memory leak in various system services
  43. [RC2] Fixed the App EOL mechanism to allow mutliple apps to be EOL
Note for changelog:
 * The fix may not apply to upgrading to this version, but any firmware upgraded after this version will not experience the issue after rebooting.
 ** These fixes were applied in the ReadyNAS OS hotfix.
WARNINGS:
  • Unless you are advised by NETGEAR Support in a support case to update to beta software, NETGEAR Support may deny support if you are running beta software. You can seek help here on the NETGEAR Community for issues encountered on the beta.
  • Devices updated with 6.9.4 firmware should not be downgraded to firmware versions before 6.9.0.
  • ReadyNAS 102, 104, and 2120 must not be updated directly to 6.9.x from 6.3.x or older firmware.  They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then onto 6.9.x.
  • ReadyNAS 202, 204, 212 and 212 must not be updated directly to 6.9.x from 6.3.x. They must first be updated to 6.3.5 then 6.5.2 and then onto 6.9.x.
KNOWN ISSUES:
  • None
Message 1 of 4
OOM-9
NETGEAR Expert
Re: ReadyNASOS 6.9.4-T43
Message 2 of 4
OOM-9
NETGEAR Expert
Message 3 of 4
OOM-9
NETGEAR Expert
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 9831 views
  • 2 kudos
  • 1 in conversation
Announcements
