Orbi WiFi 7 RBE973
Reply
ReadyNAS 2100 will not boot
Mobie
Hello, I am facing problem with ReadyNAS 2100
i did a os update to latest one my 2100 froze after boot
i have tried to reboot several times
I have tried to Firmwear upday ,os reinstall etc it will not go past menu option
ie if i chouse to firmwear or os reinstall it will just frezz and go no further
i know the drives are ok this is just softwear problems i need urgent help many thank s
Model: RNRX4000|READYNAS 2100 4TB ADVANCED NETWORK STORAGE|EOL
Message 1 of 7
Accepted Solutions
Mobie
Re: ReadyNAS 2100 will not boot
ty for your help in the end i got unit replaced from person i brought it from but now have another problem more urgent under another message
Message 7 of 7
All Replies
mdgm-ntgr
NETGEAR Employee Retired
When you turn the NAS on what lights come on on the display?
Message 2 of 7
Mobie
ok when i turn it on it will go through a boot of sorts
Blue Flashing
eithernet 1 disk 2
eithernet 2 then act
then fans slow down
then both eathernet and steady blue
this happenes with or with out hadd in place i have also tried the dicks from my other 2100
when i go into boot mode
ie press reset whilest turning on i goto any mode
factery reset for one
i hold the reset down till all hdd lights on
i press backup to disk 2 or 3 press reset again
and then thats where it stays it will do nothing execpt sit their
i was told to try a usb recovery
was told to press and hold resert for 15 sec i did all disk leds on then nout nothing happens i have tried 3 usb drives two scandisk and anoher uknown
when  i do this two of the usb had indercators on them and i can see to start acitivaty then nothing
it was fully working untill i did a os install then it froze and now its bricked ie it will not go pasted the boot sequence i hope tgis helps
you asked me to put into test mode it haung on that too
Message 3 of 7
Mobie
forgot to mention raidar cat see it cant fined it
Message 4 of 7
mdgm-ntgr
I was going to suggest USB Boot Recovery next.
The 2100 has a backup button on it so you probably have to press that to do USB Boot Recovery. Our current rackmount models don't have a backup button.
  1. Press and hold backup button
  2. Press power button briefly to turn NAS on
  3. Continue holding backup button.
It could be longer than 15 seconds that you need to press the backup button in. There's no harm in holding it longer than necessary. If you don't hold it in long enough it won't do the USB Boot Recovery.
Within a couple of minutes or so the unit should have powered off.
Message 5 of 7
mdgm-ntgr
Hi Mobie, did you try these steps?
Message 6 of 7
Mobie
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 4843 views
  • 1 kudo
  • 2 in conversation
Announcements
